02 C5 OverHeating Problem needs help?
Old Sep 22, 2012 | 02:17 AM
Rocket02's Avatar
Rocket02
Default 02 C5 OverHeating Problem needs help?
Hi, I have a 02 C5 Auto (with only 29k miles on it)that started overheating on me, no it didn't puke on me, just started to get up in the 260 range and a message came across the dash board stating, Warning Engine Now Reducing Power. So I pulled over and let it set for 15mins, then loosen radiator cap, let out about a half gallon of fluid. Restarted-was in the 220 range and suddenly went back up again to 260. When the A/C was turned on the Passenger Fan worked fine. Both fans turn freely....by hand, Fluid is circulating from engine to radiator so I'm thinking the Thermostat is working but something is not turning on the fans even at 260degrees. Hmmm?? So, I've read thru some of the threads to check out the fuses and relays. All fuses are working and not blown, however, I'm not sure how one goes about checking the Relay Switches. I pulled them out and examined them for burn spots or marks.....none.... they look good. I don't see any codes being thrown to the message board. Is there a way to check to see if the Relay is Good or Bad??? Is there Another Sensor that could cause the Fans Not to work. Again, with the engine running neither fan works but as soon as I turn on the A/C the right fan comes on. ~help~ Any suggestions would be greatly appreciated.
Thanks ....Rocket
Old Sep 23, 2012 | 07:47 PM
Rocket02's Avatar
Rocket02
Hmmm? I think I'm on my own here. That's cool, I'll still figure it out with the help of this forum and other posting and threads. Maybe everyone is out enjoying the nice weather this weekend.
Old Sep 23, 2012 | 07:58 PM
lucky131969's Avatar
lucky131969
Thanks ....Rocket
Codes don't get displayed on the "message board", they are stored. Do you know how to pull codes?
Old Sep 23, 2012 | 08:19 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old Sep 24, 2012 | 05:59 PM
Rocket02's Avatar
Rocket02
Now this is the information I've been craving. I'll read through a couple times until I have most memorized, take my laptop with me, in case I forget a step and I'm sure this will help a LOT, plus its something I never knew existed. Thank you soooooo much!!! ...Rocket
To 02 C5 OverHeating Problem needs help?
