Engine ground pics. Anyone have them?
Old Sep 24, 2012 | 04:40 PM
Chicago1's Avatar
Chicago1
Default Engine ground pics. Anyone have them?
Does anyone have actual engine bay pics that show all the grounds? I followed this link and it had the drawings http://forums.corvetteforum.com/c5-t...e-grounds.html. I'm having issues putting the black and white pic to the actual placement in the engine bay. Thanks
Old Sep 24, 2012 | 04:59 PM
lucky131969's Avatar
lucky131969
Not trying to be an ***, but I don't know what to tell you brother. You can tell from the drawings which side is which, just by looking at how the exhaust curves back. First drawing is left side of motor, second drawing is right side of motor, and third drawing is the left rear head. If this does not make sense to you, you should probably take it to a trusted shop.
Old Oct 3, 2012 | 08:38 AM
Chicago1's Avatar
Chicago1
After my cps issue I looked at the drawings and the links 8VETTE7 found and found them all. Thanks for the info gents.
Old Oct 3, 2012 | 10:58 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just so anyone that needs to know where the chassis grounds are; All the C5 and C6 chassis ground points are symmetrical on the frame. If you find a ground point at one point on the chassis, there will be one just like it on the other side of the frame. All the C5 engine grounds are also symmetrical except G-107 which is on the back of the driver’s side head only.
97 and early 98 (rear mounted EBTCM) are the only C5s that have a ground wire on G-402. All the late 98+ C5 do not use that chassis ground point and you will find a rubber cap on the stud.
Along with chassis grounds are Splice Packs (SP)
Splice packs join multiple circuit grounds to one central connector and then ground that connector to a chassis ground point thru a single wire.
Here is an example of a splice pack. It’s a chassis ground connector without the metal ground tab. There is a shorting buss in the connector that connects all the pins together:
Splice packs can get dirty and corroded just like the standard ground connectors:
BC
To Engine ground pics. Anyone have them?
