Tpms
Old Sep 25, 2012 | 08:56 PM
erngrn's Avatar
erngrn
3rd Gear
Default Tpms
My TPMS sensors are not working any longer. When I start my car a message comes up to check them. How do I get this message to stop coming up without buying new sensors. Ernie
Old Sep 25, 2012 | 09:01 PM
erngrn's Avatar
erngrn
3rd Gear
Default Tpms
1999
Old Sep 25, 2012 | 09:28 PM
87SAM's Avatar
87SAM
You can't, without working sensors.
Old Sep 25, 2012 | 09:58 PM
f6john's Avatar
f6john
All four not working? When you go to check tire pressure in the DIC you only have a blank space by the LF RF LR RR? DIC says check tire pressure, service tire pressure monitoring system? Happened to me a few weeks ago at the LS Fest after being on the dyno. Resolution of the problem for me was to disconnect the battery, Contacts looked clean, I walked away for an hour or so, came back re-attached the cables and the messages never came back and a short drive showed all four sensors operating. 99 FRC w 62K miles. Can't hurt to try and a cheap fix for me, just wish I understood why/how it solved my problem.
Old Sep 25, 2012 | 10:06 PM
jrose7004's Avatar
jrose7004
You.ll have to press reset everytime.
Old Sep 26, 2012 | 01:15 PM
erngrn's Avatar
erngrn
3rd Gear
Do you know, if I were to take the sensors out and put regular valve stems in would the message still come up. Ernie
Old Sep 26, 2012 | 01:32 PM
dblerman's Avatar
dblerman
Yes, the message would still come up.
The ONLY way to get rid of the message is to put working sensors in the wheels.
Old Sep 26, 2012 | 01:53 PM
cdkcorvette7's Avatar
cdkcorvette7
Old Sep 26, 2012 | 02:16 PM
tentuna's Avatar
tentuna
Noticed a real increase in the number of TPMS threads, either time for batteries to go dead or weather is effecting the sensors.
Old Sep 26, 2012 | 04:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Tire pressure sensor rebuild -
http://forums.corvetteforum.com/c5-t...post1570376652
Old Sep 26, 2012 | 07:39 PM
f6john's Avatar
f6john
Hmmmmmm, I had the same issue as the op, didn't replace anything, didn't rebuild anything, didn't do a relearn procedure, just disconnected the battery and then reconnected. Everything went back to normal and has been fine for the last 2 weeks. But rather than try that, I guess it would be better to just buy 4 new ones.
Old Sep 27, 2012 | 02:24 PM
Bikerboy9999's Avatar
Bikerboy9999
Default tpms
I would think your tpms would start failing one wheel at a time if it were batteries dying. Before you invest the money to tear down the wheels and replace the sensors I suggest you find a friend with an early c5. park right next to him and follow the procedure to have your c5 learn the signal from your friends working sensor. if the horn blows then your computer is working and you can proceed to step two. Step two would be to get four known good sensors and put them into an air tight pvc tube fitted with a valve so you can pressurize the tube. pump up the tube to 30 psi and follow the steps to program the sensors to the car. If this works you can continue to cheat the system for as long as you want and do nothing to your existing wheel/tire combo.
Old Sep 27, 2012 | 02:39 PM
87SAM's Avatar
87SAM
Old Sep 27, 2012 | 03:03 PM
dblerman's Avatar
dblerman
Originally Posted by 87SAM
Why waste the time and money to buy perfectly good sensors and then not bother to actually use them? Seems a lot easier/cheaper to just hit reset every time.
Old Sep 27, 2012 | 03:18 PM
dave89gta's Avatar
dave89gta
Not to mention that a failure with the following setup can have very serious consequences. Ask me how I know...
Old Sep 27, 2012 | 10:21 PM
cruisemon's Avatar
cruisemon
Replace the 97-00 no longer produced by OEM way too expensive originals with
http://forums.corvetteforum.com/c5-p...house-com.html
Find Vette Magazine for December at the book story and buy it.
Read the great article on fixing your problem
Charlie
To Tpms
