checking spark plug wires
Old Sep 25, 2012 | 11:38 PM
Irish Whiskey's Avatar
Irish Whiskey
Default checking spark plug wires
After removing each spark plug wire I need a way to check if it is still in good working order....
Old Sep 25, 2012 | 11:50 PM
sunchaser73's Avatar
sunchaser73
Use a multi-meter and check resistance. You'll need to consult the service manual or the manufacturer for the acceptance specification.
Old Sep 26, 2012 | 12:00 AM
RonSSNova's Avatar
RonSSNova
You need to make GOOD contact inside the boots when using a DMM. Alligator clips work pretty well.
Resistance will be close for all of them.
It is the outlier you are looking for.
Also, you need to bend them around a bit while checking...not a whole lot, like 90 degrees or anything, just a bit. They can become intermittant.
Ron
Old Sep 26, 2012 | 03:08 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The resistance spec for your wires is 250-750 OHMS. Most will ohm out around 300-500 ohms.
Make sure that the metal terminals inside the boot ends are not corroded or burnt and the wire jackets and boots are not burnt or cracked.
BC
Old Sep 26, 2012 | 03:49 PM
3boystoys's Avatar
3boystoys
My Napa's measured 80 ohms.
Old Sep 26, 2012 | 04:20 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When your running high frequency high voltage thru a wire,,, resistance of the wire doesnt matter too much if any!
The voltage flows on the outside of the conductor (Skin Effect).
BC
Old Sep 26, 2012 | 04:22 PM
3boystoys's Avatar
3boystoys
BC
Secondary ignition is not all that high a frequency.
Old Sep 26, 2012 | 04:24 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you are concerned about spark plug wire resistance, run down to the speed shop and get some super whamodyne solid copper spark plug wire. Then it will read ZERO resistance.
Your PCM and radio will not be happy but, you will have the lowest spark plug wire resistance of any of us!
Old Sep 26, 2012 | 04:25 PM
3boystoys's Avatar
3boystoys
Happy with the 80 ohmers I have and the price at Napa was pretty good too.
Old Sep 26, 2012 | 05:22 PM
sean.b's Avatar
sean.b
if they're really really really bad, they'll glow at night. it looks like something out of a movie - put it in a dark garage and rev it, and you'll see them light up blue. only had one set get so bad they'd do this, and it wasnt on a c5, but its possible.
Old Sep 27, 2012 | 01:06 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Guess ir depends on what the RPM of the engine is.
About 6000 RPM would be pretty high!
BC
Old Sep 27, 2012 | 07:52 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Not to sound like a pompous ***, but given how easy the LS wires are to change, and how (relatively) inexpensive a set can be, I'd just replace them, if there's ANY question on their condition....
Old Sep 27, 2012 | 09:18 PM
Irish Whiskey
My car has the Magnecor 8.5mm wires...$100 plus to replace
Old Sep 27, 2012 | 09:49 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Magnicors are also excellent wires. I purchased my magnacores waaaaaaaaaaay back in 2000 for my 98 coupe. When I sold the car, I put the OEM wires back on the 98 and put the magnicores on my 02Z. The magnacores are STILL going. They were expensive but lasted a LONG LONG time!
I have a set of the GM Performance red wires to replace them because you can not best the price and quality.
To checking spark plug wires
