Condensation ?
Old Sep 26, 2012 | 08:31 AM
John J.Bilella Jr's Avatar
John J.Bilella Jr
Navigator
Default Condensation ?
Replaced blower Motor on 01 Vette. Old blower had rust and seized also plug in on blower also had rust, where was condesation coming from ? Is there a a condensation tube or line that may be clogged ? Cost $600 parts and labor
Old Sep 26, 2012 | 08:35 AM
John J.Bilella Jr
Navigator
Replaced blower Motor on 01 Vette. Old blower had rust and seized also plug in on blower also had rust, where was condesation coming from ? Is there a a condensation tube or line that may be clogged ? Cost $600 parts and labor.
Old Sep 26, 2012 | 09:42 AM
3boystoys's Avatar
3boystoys
It's probably the "udders" that allow condensation OUT. They are known to plug up. You can clean them out.
Old Sep 26, 2012 | 12:20 PM
egrand333's Avatar
egrand333
More likely the rubber drain tube for the a/c condensation that comes out of the firewall is plugged up.
Old Sep 26, 2012 | 02:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Look on the passengers side fire wall just behind the passengers head:
Old Sep 26, 2012 | 03:25 PM
jim993's Avatar
jim993
I was able to reach that 90 degree elbow from below, remove and clean it, with the car on jack stands. Much easier than trying to get it from the top.
Old Sep 26, 2012 | 05:10 PM
John J.Bilella Jr
Navigator
Do not understand statement. Passengers sideFirewall just past passengers head ?
Old Sep 26, 2012 | 05:26 PM
John J.Bilella Jr
Navigator
How long should car run with Condesation to show ?
Old Sep 26, 2012 | 06:15 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The back side of the passengers head near the fire wall. You can see it (well part of it) below the wire harness in the pictures above.
Depends on how humid it is out side. Usually drips around 10-15min if it humid.
Old Sep 26, 2012 | 06:56 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
It's the right side (passenger side) engine head, that Bill is referring to, just to clarify that a bit.
I hope you weren't looking to find the drain utter anywhere near your passenger's head!
Old Sep 26, 2012 | 08:35 PM
John J.Bilella Jr
Navigator
Thanks Guys, ran the car for about ten Min. No water coming out
Old Sep 26, 2012 | 08:46 PM
3boystoys's Avatar
3boystoys
You WANT water to come out, especially with the AC on.
Old Sep 27, 2012 | 08:44 AM
John J.Bilella Jr
Navigator
Does Battery have to come out to get to plug or do you suggest access from underneath or a lift ? I had car running with AC on for about 10 Min, quite distubered no water dripping. About how long should it take for a dripping ? Thanks again everyone has been super but just paid $600 for fan and relay, did not know if mechanic cleaned drain pipe
Old Sep 27, 2012 | 09:39 AM
3boystoys's Avatar
3boystoys
Depends on how humid it is but you should get some "drippage" within a few minutes of the AC being on.
Old Sep 27, 2012 | 01:27 PM
jim993's Avatar
jim993
If it is plugged, it won't be dripping, that is the problem.
Don't take the battery out. Put the car up on jack stands and remove the elbow from underneath. Clean it and put it back. Easily done.
Old Sep 27, 2012 | 02:56 PM
LoneStarFRC's Avatar
LoneStarFRC
After removing the old blower, I have no doubt the mechanic reached up into the hole to check for, and remove, any debris (dirt/mouse nests/dust bunnies/pollen, etc) that can block water drainage before slapping the new blower in place.
Old Sep 27, 2012 | 03:13 PM
3boystoys's Avatar
3boystoys
REALLY, no DOUBT. Measure twice-cut once. Check it yourself.
To Condensation ?
Old Sep 27, 2012 | 10:25 PM
jim993's Avatar
jim993
You cannot get a finger into the hole and then turn 90 degrees to clean the far bottom end of the rubber ebow. Take it off from underneath and clean it right.
Old Sep 28, 2012 | 09:23 AM
m6 c5's Avatar
m6 c5
Good luck getting it back on once you take it off to clean it, I ended up just leaving it off mainly because I dropped it and couldnt find it.
Old Sep 28, 2012 | 04:24 PM
LoneStarFRC
Tip: A long zip-tie works well for this purpose and is less likely to knock/pull the elbow off the nipple.
