Error code: C1287 H C ???
Old Jun 3, 2002 | 11:24 AM
SmokieTheZ's Avatar
SmokieTheZ
Default Error code: C1287 H C ???
28 TCS - C1287 H C
This code has been coming up intermittently, but now it's not going away. I'd like to find out what it is before I take the car to the dealer...
Other codes in the history were:
60 IPC - U1160 H
A0 LDCM - U1064 H
A1 RDCM - U1064 H
After clearing, these codes did not return. If anyone knows what these codes are, or where I can find out about them, I'm interested.
Thanks,
-Aaron
Old Jun 3, 2002 | 02:38 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Error code: C1287 H C ??? (SmokieTheZ)
DTC C1287 Steering Sensor Rate Malfunction
Old Jun 3, 2002 | 03:12 PM
SmokieTheZ's Avatar
SmokieTheZ
Default Re: Error code: C1287 H C ??? (wallstAL)
Interesting... Thanks for such a quick reply. :cheers:
Old Jun 3, 2002 | 03:18 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
I'm getting that one along with a C1288
See here:
http://forums.corvetteforum.com/zerothread?id=309209
Old Jun 3, 2002 | 03:28 PM
Hex29A's Avatar
Hex29A
60 IPC - U1160 H
A0 LDCM - U1064 H
A1 RDCM - U1064 H
60 IPC – Instrument Panel Cluster
U1160 Loss of Communications with LDCM
A0 LDCM – Left Door Control Module
A1 RDCM – Right Door Control Module
U1064 Lose of Communications with DCM
Old Jun 3, 2002 | 03:34 PM
PeterK's Avatar
PeterK
St. Jude Donor '12
2012 Election Contest Winner
Default Re: Error code: C1287 H C ??? (Hex29A)
I had it too. Dealer was able to fix in a first attempt.
To Error code: C1287 H C ???
