turn signals
Old Sep 30, 2012 | 10:36 AM
fitguy5050's Avatar
fitguy5050
Default turn signals
sometime they work and sometimes they do not at all . 2002 z06
Hazzard switch or turn signal arm or is there a relay somewhere ?
Thanks Jerry
Old Sep 30, 2012 | 10:44 AM
fitguy5050's Avatar
fitguy5050
Thanks , ive pushed the Hazzard switch and sometimes that helps , not all the time .
Do you have to remove the sterring wheel to pull the stalk out ?
Old Sep 30, 2012 | 11:37 AM
lionelhutz's Avatar
lionelhutz
I would bet hazard since all signal power starts there making it a single point of failure.There is a pair of contacts that switch the power to the hazard switch between keyed power for turn signals or hot all the time power for the hazards. I'd expect the keyed power contact is failing.
There's no single contact in the turn signal switch that could fail and cause all the signals to not work so the chances of it being the turn signal switch are low.
A couple of spade connectors and a $10 flasher from an automotive store will fix it if you don't mind cutting the wires and splicing a flasher in under the ignition switch.
Old Sep 30, 2012 | 07:32 PM
fitguy5050's Avatar
fitguy5050
Thanks guys , i ordered a Haz switch off ebay . Hope thats all it is .
Old Sep 30, 2012 | 07:47 PM
maxx2200's Avatar
maxx2200
When my turn signals went out on mine, it was the hazard switch. My brake lights went out and that was my multi-function switch. Good luck, no matter what it is, the information posted above will most likely guarantee a successful repair. We're lucky to have this forum.
To turn signals
