Shifter KNob
Old Sep 30, 2012 | 05:12 PM
tentuna's Avatar
tentuna
Default Shifter ****
If I can find a C6 shifter ****, is there any modification needed to use it on a C5 shifter?
Old Sep 30, 2012 | 06:06 PM
bumble-z's Avatar
bumble-z
A stock C/5 shifter shaft is 9/16"-18
A stock C6 **** will not fit.
You can purchase an aftermarket C6 **** with 9/16"-18 & of course, it will then fit.
Old Sep 30, 2012 | 06:12 PM
tentuna's Avatar
tentuna
Thanks,
I knew the C5 was a 9/16x18, did not know about the C6 ****, what is the mod?
Old Sep 30, 2012 | 06:27 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by tentuna
Thanks,
The C6 slips down onto the shaft. No threads. It's held in place by a single screw on the side of the **** near the bottom. With boot in place you can't see it.
Not really sure if the threaded C6 ***** being offered by a couple vendors are OEM ***** that have been threaded for C5s or are reproductions made with threads. I'm thinking they are likely OEM that have been threaded.
HTH
Old Sep 30, 2012 | 06:54 PM
bumble-z's Avatar
bumble-z
Ebay has the C/6 *****, threaded 9/16"-18 to fit the stock C5 shafts.
Item # 400273995449
Old Sep 30, 2012 | 07:58 PM
hdkeno's Avatar
hdkeno
I got my c6 shifter **** from gscreations it has a self threading polymer boss inside that locks in when you screw it on. But i put some loctite blue on for extra measure. Feels great, BIG improvement over the dated stock shift ****, and has never lossened up.
To Shifter KNob
