i'm replacing all four calipers ,brackets and rotors (98 vette) should i replace the mounting bolts or just use the old ones if not damaged...these bolts are $8.00 a peice (8 needed) thank you in advance phil52277
Use a wire wheel to brush the old Locktite out of the threads, apply red Loctite when re-installing. Or, you could pay a couple bucks apiece over the Goodwrench counter for new ones. Here's a tip for removing the old bolts which were probably originally torqued to 90 ft-lbs plus they were Locktited: Use a propane torch to heat the threaded part of the "knuckle" that mounts the bracket bolts for a 60 second count. This will soften the original Locktite making removal easier, especially if the car is on the ground. Anybody with a lift can use a big breaker bar from the bottom.
thanks for the tip...i'm considering having them professtionally installed austen-spencer will do all four brakes and rotors for $150.00...does that seem like a good price?
bluefire, i know the says change them, but i even checked with the local chevy dealership and they said they never replace them unless they are damaged...and at $8.00 a peice if i don't need to change them i guess i won't...thankyou everyone phil52277
I thought you were talking about the caliper mounting bolts not the bracket bolts... Man I'm out of it today.
I don't replace mine every time I swap rotors because I use different rotors for street and track so it would get very expensive buying new bolts every time. That said, if you don't swap rotors very often probably wouldn't be a bad idea to replace them since they are tty.
Not sure that you received the correct quote on the bolts, but the smaller
bolts that holds your calipers on, requires a total of eight.
GM part number 14067559.
They will have loc tite on the threads.
If you are not the original owner of the car & have no idea if the previous owner or machanic ever "over tightened" them, I'd go ahead & replace them all.
How ever, going forward, it would be fine to reuse.
Never over tighten.
Clean the old loc tite off with a 8mm x 1.25 die.
Believe me it works great & fast.
Put a dab of loc tite on each bolt, & your good to go.
Never over tighten.
I agree with ya on the thread cleaning. If you have a thread chaser it's good inside the holes too.
Plus, a little acetone on the threads first, dissolves the old Loc-Tite pretty quickly.
