Rocker cover picture
Old Oct 3, 2012 | 02:57 PM
ttz's Avatar
ttz
Default Rocker cover picture
I'm looking for a picture of the underside of the stock LS6 rocker cover on the passanger side. Anyone happen to have one?
Old Oct 3, 2012 | 03:01 PM
lucky131969's Avatar
lucky131969
Here you go:
Old Oct 3, 2012 | 03:23 PM
ttz's Avatar
ttz
Thanks. Where is the port for the PVC system? Is it hidden by what looks like a splash shield?
Old Oct 3, 2012 | 03:26 PM
ZeeOSix's Avatar
ZeeOSix
Should be a hose nipple on the outside near the top front of the valve cover - the "fresh air" hose runs from there to the nipple that is located upstream of the throttle valve. And yes, you can't see it from the inside like the photo is orientated.
Old Oct 3, 2012 | 03:42 PM
ttz's Avatar
ttz
Do you usually need to replace the gasket if you pull the cover?
Old Oct 3, 2012 | 03:43 PM
lucky131969
Yes.
Old Oct 3, 2012 | 04:17 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Unless you SOAK the cover in a solvent or damage the gasket,, it is 100% reuseable.
If you get brake parts cleaner on it, it will cause it to SWELL and you will end up purchasing a new one. (Ask me how I know??????)
To Rocker cover picture
