Brake Fluid Replacement ????'s
Have a good one,
Mike
Fluid DRY WET
Castrol LMA DOT 3/4 446 311
Ford Heavy Duty DOT 3 550 290
ATE Super Blue Racing 536 392
ATE TYP 200 536 392
Motul Racing 600 585 421
Castrol SRF 590 518
Performance Friction 550 284
That's defined as the "wet" vs. "dry" boiling point of the fluid. Different brands of fluid have different boiling points, usually can be found on the container label.
Have a good one,
Mike
[Modified by gmblack3, 9:20 AM 6/6/2002]
BRAKE FLUID DATA
ARRANGED BY DRY BOILING POINT:
DRY:401F -- WET:284F --- DOT3
DRY:446F -- WET:311F --- DOT4
DRY:502F -- WET:343F --- VALVOLINE SYNPOWER
DRY:509F -- WET:365F --- MOTUL 5.1
DRY:527F -- WET:302F --- AP RACING 551
DRY:536F -- WET:392F --- ATE SUPERBLUE/TYP200
DRY:590F -- WET:410F --- AP RACING 600
DRY:590F -- WET:518F --- CASTROL SRF
DRY:593F -- WET:420F --- MOTUL RBF600
DRY:610F -- WET:421F --- NEO-SYNTHETIC SUPER DOT 610
ARRANGED BY WET BOILING POINT:
Based on this data--its Castrol SRF for my high performance cars.
[Modified by MitchAlsup, 10:27 AM 6/6/2002]
Castrol SRF is a hyper-exotic and hyper-expensive brake fluid that is generally used by wealthy Porsche owners at track events. I've seen prices of $78 per liter for this stuff. Sold in metal cans.
Ford Heavy Duty DOT 3 is VERY inexpensive and is popular among racers because of its excellent dry boiling point. It absorbs moisture quickly, but the racers don't care since they change their fluid frequently. Comes in metal cans so it may be stored. I would not use this in my Impala for the street.
ATE Super Blue Racing and ATE TYP 200 are the same brake fluid in two different colors (blue and amber, respectively). BMW recommends this brake fluid for their street cars because it, like Castrol LMA, absorbs moisture very slowly. The advantage over LMA is that ATE has a much better wet boiling point. You can put this stuff in your car and forget about it for a long time. An excellent choice for a weekend track car which also sees regular street duty. Comes in metal cans. This is what I use in all my street cars.
Motul Racing 600 is a very exotic and expensive synthetic fluid with high wet and dry boiling points. I use this exclusively in my race cars. Too expensive for the street and requires frequent changing due to its hygroscopic nature. Sold in plastic bottles. It is not suitable for the street because it absorbs moisture quickly.
