engine light
Old Oct 5, 2012 | 07:10 PM
judson whitley's Avatar
judson whitley
Default engine light
found the gas cap not secure put back on book says should reset put 75 miles so far anyone has done before and how long to reset thanks, 2010 GS
Old Oct 8, 2012 | 11:10 AM
waddisme's Avatar
waddisme
Search resetting engine codes and it will walk you through how to reset it yourself.
Old Oct 8, 2012 | 11:36 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You posted in the C5 Tech section BUT,,, no worries.. Were all corvette brothers.
If you indeed fixed the issue that caused the DTCs to pop,, the ECU will clear the HISTORY code after a number of driving cycles.
However,, your C6 does NOT have the ability for the owner to pull up the DTCs on the DIC like the C5 does.
You should go to AutoZone and ask them to read the ECU and figure out why the ECU popped a DTCs.. They read them for you for FREE!
I purchased an ACTRON Scanner that is CAN BUS Compliant for my C6. I can read and clear my own DTCs. There are inexpensive and invaluable!
BC
Old Oct 8, 2012 | 07:23 PM
judson whitley
Sorry didn't realize the year mistake till after post call the Hendricks rep she said should reset unless gas cap bad still under warranty taking back tues thanks for the help
To engine light
