Launch techniques for ET Streets
Old Jun 4, 2002 | 08:23 AM
Scott97's Avatar
Scott97
Default Launch techniques for ET Streets
I picked up a set of Mickey Thompson ET Streets and 16" to replace the Nitto DR's
What type of burnout and launch yields the best results without snapping an output shaft?
I was planning on spinning them in the water for a couple of seconds, then doing a 5 second burnout, then spinning them to the line.
Is a 3500 rpm drop to excessive?
Old Jun 4, 2002 | 12:06 PM
Scott97's Avatar
Scott97
Default Re: Launch techniques for ET Streets (Scott97)
Guess I should have mentioned Zaino, or a dress up mod as well. :lol:
TTT
Old Jun 4, 2002 | 01:20 PM
lostsoulny's Avatar
lostsoulny
post this over in teh new drag racing section you will get replies there :seeya
Old Jun 4, 2002 | 01:24 PM
boweryboy's Avatar
boweryboy
Cruise-In II Veteran
Scott,
Assuming you have a very good aftermarket clutch and a beefed up rear end (hardened half shaft/cryo treated gears);
Set the pressure to about 15psi, do a real smokey burnout and laund the car hard at about 4500RPM with no slip.
If nothing breaks :) you will launch like a bat out of hell and get a 1.6x 60 foot!
I did 4 of these two wknds ago and had 4 1.6x 60 foots with worn ET streets.
Old Jun 4, 2002 | 01:31 PM
Scott97's Avatar
Scott97
Default Re: Launch techniques for ET Streets (boweryboy)
Thanks Bill.
I have an aftermarket clutch but no hardened output shafts... Yet. :lol:
You think I can squeeze out a few runs before snapping the output shaft?
Old Jun 4, 2002 | 01:44 PM
TXNC5's Avatar
TXNC5
Should I tell how well you launched in my car? How good the burnout was? If I only had a camera.
We will have to go bust all over RCR next week when my CCW's get here! I can't wait, but I probably can't make it tomorrow.
Old Jun 4, 2002 | 01:46 PM
boweryboy's Avatar
boweryboy
Scott,
I would be careful. The input shaft is the week link. I have seen many snap clean on lesser launches then 4500. The way I approached it before I had mine was I figured if it snapped I would just replace it. But I had a trailer with a winch :).
If it was me I would go for it, but thats me Mr Vegas :)!
P.S. Caution this is an addictive activity! Once you do it you will be addictied to the sensation :D!
Good Luck Scott.
Old Jun 4, 2002 | 02:03 PM
Scott97's Avatar
Scott97
That was funny as hell! :lol:
Way different than launching/burning out on DR's.
I ran John's car once at the track and lets just say it was pretty comical. :yesnod:
The tall shifter, stock rev limiter and pathetic first time launch on ET Streets
was priceless.
Scott,
Good Luck Scott.
:lol::lol::lol::lol::lol::lol::lol::lol:
And don't call me Francis...Any of you homo's call me Francis and I'll kill ya...
Stripes is one of my favorite movies.
Well Bill, as any of my friends will tell you, I'll be dropping the clutch around 4500 regardless. :reddevil
And without a trailor I might add.
:crazy: :crazy: :crazy: :crazy: :crazy: :crazy:
I'll try to launch easy the first couple times, but after that I'll have to try at least one or 2 higher launches.
I'm definately going to put a hardened output shaft in within the next couple of weeks.:yesnod:
To Launch techniques for ET Streets
