headlight trouble
Old Oct 10, 2012 | 06:37 PM
WHoisu05's Avatar
WHoisu05
Default headlight trouble
Installed a set of hid headlights worked fine for a few months now the driver side went out... took the hid out of the driver side and put back the normal bulb still wont work. but if i switch over to bright lights they both work any thoughts on why every light works but the dim driver side headlight
Old Oct 10, 2012 | 11:09 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Did you change the wiring for the hids to use a resistor?
The hids often times require more juice to fire on. Some have reported hid problems having to flash their brights a few times to make them work.
There is a fix using a resistor for this issue. I would also check the faq and look at bill curlee info on cleaning the wire connection near the head light on the wheel well.
You could even be experiencing a problem with the head light switch that can be repaired by bending a couple of connections. I had no head lights before i did this repair and in the process only had one head light powering on before bending contacts a bit more.
Guessing game at this point but my best guess would be to inspect wires/ground points since you have the issue with low beam and hids.
Old Oct 11, 2012 | 09:30 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Had a similar situation occur with one side not working after a couple of weeks. The ballast and bulb proved to be fine. I changed to a relay harness powered from the battery (actually the postive post on the fuse box). So far it is working fine. The resistor (which I have) is more to avoid the light buckets from operating improperly, as not going down unless the brights are on. Good luck.
To headlight trouble
