Planning head swap -- headers out?
Old Oct 12, 2012 | 02:51 PM
kernelPanicked's Avatar
kernelPanicked
Default Planning head swap -- headers out?
Hi all. I have a 2000 coupe with LTs (from ARH).
I have picked up all the parts from a 2002 Z06 top end. Planning to put those on this winter. I'm looking closer at instructions now and I see that a lot of folks remove the exhaust manifolds/headers completely to do a head swap. I have done head swaps on trucks before and not had to do this. Is this a MUST for head swap on the C5?
I have no problem getting under the car and loosening their clamps to swing them away, or even unseating them so they're just floating in the right area, but total removal is going to be a problem. I watched the ARH guys install them at Carlisle this year and they really had to squeeze in there, and the car would need to be on a lift, which I don't plan on having for this job.
TIA.
Old Oct 12, 2012 | 03:03 PM
dblerman's Avatar
dblerman
I see no reason why this wouldn't work just fine. If all you're doing is a head swap you should be able to get enough room by loosening the bolts and clamps a little bit.
Old Oct 12, 2012 | 03:08 PM
newcastle3's Avatar
newcastle3
St. Jude Donor '10
I just replaced the heads on my 99 w/ FLP headers. I had to disconnect them from the cats and just let them drop out of the way. There would have been no room if I left them connected, but I had to use a tow strap to get the exhaust to meet back up. I'm guessing because I had the front on ramps while doing this.
Old Oct 12, 2012 | 09:25 PM
kmetros's Avatar
kmetros
Just completely disconnect them and let them 'drop' as far as they can. I covered mine with a plastic bag over the top to keep coolant from dripping into them. It worked fine for me.
Old Oct 12, 2012 | 09:36 PM
kmetros's Avatar
kmetros
Here is a picture I found. Since I had the headers coated before I installed them I dropped a towel over them, then put the bags over the towels. The bags were big enough that they helped keep coolant from dropping EVERYWHERE. I was actually able to sop a bunch of it up from on top of the plastic.
Old Oct 13, 2012 | 06:37 AM
kernelPanicked
That's what I'm talkin' about, thanks man!
That picture pretty much tells me everything I need to plan to do. I think I might start sooner than I was planning, this looks like a considerable amount of work, especially with a cam going in as well.
Old Oct 15, 2012 | 11:14 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I'm one of those ARH guys at Carlisle
You'll be fine by dropping them down once the Xpipe is out of the way
Get the ShopVac ready, lots of dirt under the intake(typically)
read up on 'water in cyl bolt holes' and deck prep; or suck the coolant out of the block(clear fuel line works great with an attachment)
Old Oct 15, 2012 | 11:33 PM
kernelPanicked
Thanks Steve, I remember you. It was actually the other team that put my headers on. I was the second to last guy on that lift the first day. It was getting dark, the boss left the lights back at the hotel, and I remember my car posed some problems...they had to get the prybar out to move my engine on the mounts to clear the passenger side header, I asked them to install my Tis, I had goofy battery bolts, etc. So I consider that installation as much art as science, and I don't want to pull those things out if I can help it.
Anyway you all had a nice thing going there and I hope I can hang out at the tent for a little while next year without having to buy another set of headers.
To Planning head swap -- headers out?
