power outlet
Old Oct 12, 2012 | 05:56 PM
Paul112588's Avatar
Paul112588
Default power outlet
My 2003 corvette when I plug in my Gps device into power outlet in center console nothing happens..... does this mean I have to replace another stupid thing in this car.
Old Oct 12, 2012 | 06:39 PM
FRITZM's Avatar
FRITZM
Default Console
I believe you should check fuse #1 in the fuse box under the passenger front carpeting. The interior fuse panel is located there. I also think you will find that the console accessory port is switched on by the ignition switch. Don't quote me though.
Old Oct 12, 2012 | 11:27 PM
sunchaser73's Avatar
sunchaser73
Both plugs are "HOT ALL TIMES" but powered from separate fuses. The "electronic accessory plug" is powered by fuse #1 and the "cigar lighter" is powered by fuse #7 (on a 99 anyway...).
Check the fuse first, as mentioned above. If that isn't it, I would check the resistance of the plug/socket. A replacement shouldn't be too expensive.
HTH
To power outlet
