Battery Replacement
Old Oct 12, 2012 | 09:43 PM
Chenginator's Avatar
Chenginator
1st Gear
Default Battery Replacement
I own a 2000 Vette. My uncle has a 2004 and says he has a bad battery. When I drove his car, the car actually stopped running when I was doing about 60. It started back up again and I told him to have it checked out. He did not and it has been in storage on a tender for a few months and now won't turn over at all. Bad Battery? In my 2000, the battery is a side mount. In a 2004 are they all top post? I see mixed reviews on replacment batteries. Suggestions?
Old Oct 12, 2012 | 11:51 PM
sunchaser73's Avatar
sunchaser73
Suggestions?...Optima Yellow Top. I've read where others use the Red Top. Any quality battery that meets the specifications for the C5 should be fine. I would also suggest a CTek battery tender if he doesn't drive the car frequently. I have the MultiUS 3300 model...no issues...
Old Oct 12, 2012 | 11:59 PM
baxsom's Avatar
baxsom
I did the unthinkable. I put an Advance Gold in my 00 two years ago no issues at all. Starts fine, runs fine, never any electrical issues. With the warranty that comes with, I just cant see the point in an optima.
Old Oct 13, 2012 | 01:09 AM
NukeC5's Avatar
NukeC5
I thought power came from the alternator while the car is running and especially at speed. The battery may be dying because of a bad alternator. If it stopped while driving, I would get the alternator tested.
Old Oct 13, 2012 | 02:33 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
I just picked up a duracell agm battery at Sams for $130 w/tax. It meets vet cca and most importantly a rc of 120. I guess time will tell if it is a good choice. Top and side post. If alt was not working, would it throw a code?
http://www.samsclub.com/sams/duracel...LLER|Duracell® AGM Automotive Battery - Group Size 78DTAGM|Duracell® AGM Automotive Battery - Group Size 78DTAGM
Old Oct 13, 2012 | 03:52 PM
GEMcLean's Avatar
GEMcLean
I put in an AutoZone Duralast 86-DL in July of 2010 and it is still going strong.
Old Oct 13, 2012 | 06:33 PM
coia96vette's Avatar
coia96vette
The 2004s take the top mount type 86 battery. Replaced mine the day after I bought it two years ago.
Old Oct 13, 2012 | 11:56 PM
BigGun's Avatar
BigGun
Get the battery tested. it"s free. You could have a bad connection and the battery is fine.
Old Oct 14, 2012 | 01:25 AM
LT1driver's Avatar
LT1driver
autozone just like gmmcclean back in 2009...works great
Old Oct 14, 2012 | 10:09 AM
poppyboy's Avatar
poppyboy
Is it cranking strong (but just not starting)? If so, it's likely not the battery. I recommend first testing the starter (for starting problem) and alternator (for dying when driving).
Old Oct 21, 2012 | 09:56 PM
Spaggs's Avatar
Spaggs
I always go with the cheapest battery I can find because, usually, the cheaper battery weighs less. On tow vehicles, I go opposite. I found this out by using a fish scale.
Just my opinion.
Spaggs
Old Oct 22, 2012 | 03:58 AM
strand rider's Avatar
strand rider
that's a clever approach on weight, and good to know. I think my car's old owner saved weight by taking out every third screw.
To Battery Replacement
