C5 vs C6 headers
Old Oct 13, 2012 | 08:16 PM
bracketshark's Avatar
bracketshark
Default C5 vs C6 headers
Well i did it again, I bought this set of headers off fleabay: http://www.ebay.com/itm/380478954841...84.m1439.l2649
Stated to be for a 97-04 corvette, I got them in and they appear to be way to long, the cats are going to set way back in the tunnel area. could they be for a C6? The end of the collector is going to be at the back side of the original cats measuring from the support mounts on the bell housing.
Old Oct 13, 2012 | 09:39 PM
RonSSNova's Avatar
RonSSNova
Some C5 headers are long like this. It's a good thing for torque.
What brand?
Ron
Old Oct 13, 2012 | 09:46 PM
robert miller's Avatar
robert miller
What brand?
Ron
Plus if you didnt get the 02,s wiring, you will have to buy now the ext wiring for the stock one,s. 80.00 more with more mod,s come more money.Robert
Old Oct 13, 2012 | 10:04 PM
bracketshark
I did get a pair of o2 extensions with the headers. it looks like the fronts will have to have them also. the end of the collector is @ the end of where the stock cats sit, so the cats will be in the tunnel area is that OK?
Old Oct 13, 2012 | 10:46 PM
C5FORFUN2's Avatar
C5FORFUN2
Looks like a nice setup. With that Xpipe you should be fine where the cats are mounted.
Old Oct 14, 2012 | 08:03 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Those are C5 headers. The connection to the over axle pipes are different for the C6.
Old Oct 14, 2012 | 11:08 AM
bracketshark
Can the rear O2's be tuned out? Is this a bad idea?
Old Oct 14, 2012 | 11:45 AM
RonSSNova's Avatar
RonSSNova
They can be with HPT or EFI Live. It is done all the time. They simply monitor CAT function, not sure how, but none to the wiser if shut off.
Ron
Old Oct 14, 2012 | 04:30 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Steve
Those headers are of a tuned long primary header. Makes excellent TQ,, As long as the CATS are in the cat bay, you should be good to go.
Here are my headers. They are Stainless Works with the shorter primaries:
I purchased some C6 XS Power headers for my 06 Coupe and this is how they look:
Old Oct 14, 2012 | 09:01 PM
bracketshark
Bill, should I leave the rear O2's in or plug the hole and have them tuned out? I could see yours were still in place. I'm hoping to get it to 425-435 RWHP after the fast 90, T/B, Vararam, a head change and new cam. Street stomper only.
Old Oct 14, 2012 | 11:02 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The rears are there only to tell the PCM if the CATs are working efficiently or not. Mine are now TUNED off. If you have long primary headers, if you try to use the rears, you may wind up throwing CAT codes due to CAT inefficiency.
I would have then tuned OUT so you don't need to worry about them any more...
To C5 vs C6 headers
