Fan Belt Issues
Old Oct 15, 2012 | 11:01 PM
Wolfraven's Avatar
Wolfraven
Navigator
Default Fan Belt Issues
Hi
I am a new vette owner but seem to be chewing up fan belts
I suspect something out of alignment but the mechanics just keep replacing it and some bearings
Any assistance would be welcome
Thanks in Advance
BTW
2001 C5
Old Oct 15, 2012 | 11:12 PM
Zeus-of-Boost's Avatar
Zeus-of-Boost
ummm.... am i missing something????
Old Oct 15, 2012 | 11:13 PM
Wolfraven's Avatar
Wolfraven
Navigator
Missing What?
need some advice on my 2001 c5 tearing fanbelts
Am I in wrong forum
Old Oct 15, 2012 | 11:38 PM
Wolfraven's Avatar
Wolfraven
Navigator
8VETTE7
Will look at on weekend
Old Oct 16, 2012 | 02:06 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YEP! If the outer pully has seperated and has walked forward or reward, it will be out of alignment and cause the belts to jump and shread. They can also wobble.
Heres a post that has some good info on damper removal and tools.
http://forums.corvetteforum.com/c5-t...oval-tool.html
When you go this far into a repair it a GREAT time to replace the timing chain (IT WILL BE WORN) and install a new high volume oil pump!
Make SURE that you replace the cover seal along with the new damper.
If you go aftermarket, I recommend the POWERBOND Damper.
Old Oct 16, 2012 | 04:25 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Any recommendations on a supplier for the pump and timing chain? Brands, etc?
Old Oct 16, 2012 | 07:30 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
For an engine that is not heavily modified, you can easily upgrade to the improved LS2 chain and the Melling "HIGH VOLUME" pump is great right out of the box.
Both are excellent up grades over the LS1 stuff..
Old Oct 16, 2012 | 09:38 PM
K-Spaz's Avatar
K-Spaz
Ah, thanks Bill. As soon as I get time and make the tools I'll be doing this as well..
To Fan Belt Issues
