Rim/Tire suggestions
Old Oct 17, 2012 | 10:52 PM
bahunter's Avatar
bahunter
Navigator
Default Rim/Tire suggestions
First time poster!(sp?) Recently purchased '99 convertible with 38k miles. Love the car and am looking to upgrade the stock rims/tires. My car is equipped with AH. I would appreciate any suggestions for 18" front rim width and 19" rear rim width. Tire size is desired to remain within the fender wells, but wider than factory tires is desired. I would like to keep AH active but it is not necessary. Any suggestions?? Thanks for your help!
Old Oct 18, 2012 | 12:42 AM
lionelhutz's Avatar
lionelhutz
9.5" or 10" on front and 11" on rear. 275 series on front and 305 series on rear. You can look up the profiles to see what would match the stock sizes. Make sure the fronts are about 0.5" to 1" smaller in diameter than the rears.
Old Oct 18, 2012 | 08:39 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I have some info on properly sizing tires on my web site.
www.ToqueZ06.com
If your considering a 18/19 combo:
Front 9.5"-10" wide, 265/35/18, or 275/35/18
Rear 10.5-11" wide, 305/30/19
If your considering a 19/19 combo:
Front 9.5"-10" wide, 275/30/19
You will not have any issues with traction control with the above sizes.
Toque
Old Oct 18, 2012 | 06:38 PM
bahunter's Avatar
bahunter
Navigator
I appreciate the advice. Experience is hard to overcome. Looking forward to shopping.
To Rim/Tire suggestions
