Snowmobile: Drivetrain by....
Old Jun 5, 2002 | 02:42 AM
Snowman's Avatar
Snowman
CI 1-2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '03-'04-'05-'06-'07-'08-'09
Default Snowmobile: Drivetrain by....
MTI.
Those of you who were at the Cruisein drags got to witness my first and only run on nitrous at the track with slicks. I had checked a/f on the dyno NA with Tom in Atlanta, sorted out the nitrous system so it would work (didn't go back to the dyno) (Bad connection to inline fuse) and I used up a couple of bottles trying it out on the street with street tires. (:cool:)
I did a few NA runs at Beech Bend just to get the feel of my new M12 tranny, not for major time or trap speed. Had some trouble hooking up and car seemed to kick to the left under hard acceleration. I checked tire pressures twice. Then I opened the bottle.
Did a decent burnout. Armed the system. Purged. Went out slowly in 1st as I didn't want to trigger the nitrous in 1st my first time out. Good clean fast shift into 2nd. Poured it on including the nitrous....it was pulling like mad...and somewhere in those few moments in 2nd, I drove through the clutch.
Note: I have been VERY happy with my Cartek clutch on the street and on the track (NA) but we knew that on nitrous with slicks, the car would probably drive through the clutch. On the dyno back at ARE, with a half empty bottle, no bottle warmer, with the nitrous not even set to come on until 4200rpm, it still went to 725+rw and you could see it went right through the clutch.
Sure enough it did that at the track too. I went to shift into 3rd and got shut out and missed the shift, but put the clutch in again, got it into 3rd and then dumped it all in 3rd to try to pull the guy in the next lane (Buckmaster I think). The nitrous came on again and I was seriously pulling him to the lights. Did a 12.7 and 125mph which isn't totally terrible given I went out slowly and missed a shift. But at the end of the track when I went to make my turn, CLANK CLANK CLANK (a hard metallic clank) in the rear...felt like on the driver's side. I picked up my slip and drove back to the pits and parked the car. Still was making some noise particularly when I wasn't going absolutely straight. Clutch was definitely hot but I could drive the car.
I let the car cool down for about an hour. Mike Norris was kind enough to come and help me do a visual inspection. Half shafts seemed fine, no leaks, nothing visible that we could see. I then did slow figure 8's for Mike and we couldn't get it to clank again although I could hear some kind of rubbing and it seemed to want to spin the dr side rear wheel. I had Neill follow me back to the Baymont and put the car on the trailer.
In subsequent conversations, I'm pretty sure that what I broke was the posi. Several people have had similar failures. Not worth speculating anymore....time to take it in and get it fixed.
I spoke with Jayson at MTI today. Happy to take a look. I'm taking the car over on Thursday after I get back to town. While we are there, he is going to install a McLeod DD clutch for me, one of Glen's output shafts, possibly HAL shocks and do whatever it takes to restore the rear.
I appreciate Jayson for being willing to take me so quickly.
I'm looking for HAL shocks that are available and yet not at the top of the cost wave we've been experiencing with them in the last 2 months. Email me if you have ideas. Jayson may have a set, I just forgot to ask him.
I'll keep you posted. I will dyno with nitrous while at MTI and see what it will do when the clutch isn't slipping. That should be fun.
Jayson, thanks once again.
Snowman
[Modified by Snowman, 12:57 AM 6/5/2002]
[Modified by Snowman, 1:03 AM 6/5/2002]
Old Jun 5, 2002 | 03:02 AM
Nate@CorvetteGarage's Avatar
Nate@CorvetteGarage
Supporting Vendor
Cruise-In I Veteran
St. Jude Contributor '04
Default Re: Snowmobile: Drivetrain by.... (Snowman)
Sorry to hear about the snowmobile, wish we could been there at the cruise-in. Maybe next year. Good luck and dont you love that hi horsepower moddin??? :D
Nate
[Modified by Nate@xtreme, 1:05 AM 6/5/2002]
Old Jun 5, 2002 | 03:04 AM
Snowman's Avatar
Snowman
Default Re: Snowmobile: Drivetrain by.... (Nate@xtreme)
Nate, send me an email and tell me what your convert is doing so I can enter your contest! Thanks for the good wishes. I might drive my car to Arizona in July.
Doug
Old Jun 5, 2002 | 03:06 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
When you get into HEAVY mods, it seems the battle is never ending at times.
Good luck with the next round. I just had my Mcloed duel disk upgraded and having now broke it in, it works great.
Regards,
JB
Old Jun 5, 2002 | 03:12 AM
Nate@CorvetteGarage
Supporting Vendor
Cruise-In I Veteran
Doug- lol, wish I knew!
we are working on programming as we speak. Then its time to break in the clutch, about 1000 miles city driving.
Make the trip! No, you cannot have my foglamps this time! hehe
or my swaybars either! No, No, No!!!
well okay, if you really want them...
Nate
[Modified by Nate@xtreme, 1:14 AM 6/5/2002]
Old Jun 5, 2002 | 03:19 AM
Snowman's Avatar
Snowman
We've come a long ways since those days haven't we? I did drive off with more "stuff" off your car...it was amazing.
Doug
Old Jun 5, 2002 | 09:35 AM
Arnie's Avatar
Arnie
Cruise-In II Veteran
As long as the rear will be apart, you might want to consider the Mark Williams half shafts as a bit of extra insurance.
Old Jun 5, 2002 | 10:01 AM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Sorry to hear about your problems, but I'm sure MTI will have it straightened out soon and you will be runing low 10's without a problem and possible high 9's.
[Modified by Godspeed, 8:24 AM 6/5/2002]
Old Jun 5, 2002 | 11:29 AM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In VI Veteran
Doug, sorry for your misfortune man considering you probably expected better results with no mechanical failures this time around... I know your determined to get it right and we all know that sooner than later that will be the case :yesnod: Keep your spirits up and I wish you good luck in your continuing quest to have one of the best C5's out there! :cheers:
Nick
God Bless America :flag
Old Jun 5, 2002 | 01:45 PM
gonbad's Avatar
gonbad
Doug could you please e-mail me with what Jayson is charging for the clutch install. I have the Mccleod sitting in my garage here in Dallas and will be taking the car down to MTI since they seem to have the best luck with these clutches. I just need an Idea on price.
Old Jun 5, 2002 | 03:00 PM
John's vette's Avatar
John's vette
TBryne had/has a great deal going on HALs. May want to give them a call.
Doug if was fun trying to keep up with you in the mountains on the way to the CI. I am still trying to remove the finger nail marks my wife made holding on.
Old Jun 5, 2002 | 03:35 PM
NoMercy's Avatar
NoMercy
Default Re: Snowmobile: Drivetrain by.... (John's vette)
Bradda Doug!! Sorry about your recent probs but with a monster like that ... well you know. :D :D :D
Consider yourself fortunate though. You are in a great spot to race & break your car. Not only do you have the local tuners but plenty of really mod savy people to help you with any issues.
Out here in Hawaii the race & break game is not very good, unless you own an import. ;)
You and I both know Jayson will hook you up though. I can't wait to see that dyno! :cheers:
Old Jun 5, 2002 | 11:27 PM
MySea6's Avatar
MySea6
Dayum Doug!
Bet Jayson gets ya sorted out though :cheers:
Old Jun 5, 2002 | 11:48 PM
Snowman's Avatar
Snowman
Default Re: Snowmobile: Drivetrain by.... (gonbad)
Hey Michael, it's been a while! I'm living in Texas now and you way up north now! :D
Jayson and I will come to some understanding about price but it will probably be a package of some kind after we talk and after we find out what happened to the rear. I recommend you just call him and check it out directly. He's pretty much the only shop where big cube cars and McCleod clutches have been working out consistently. I figure SW is a good enough recommendation for me. This is my 3rd and last try with the McLeod. Has cost me 4k in parts and labor so far. In and out. All my early videos have a chirp just as the clutch engages.
Doug
Old Jun 5, 2002 | 11:49 PM
Snowman's Avatar
Snowman
Default Re: Snowmobile: Drivetrain by.... (NoMercy)
Bill, do you have your car there now? How's the street scene with that badboy?
Doug
Old Jun 6, 2002 | 12:11 AM
NoMercy's Avatar
NoMercy
Doug
It's on the boat as I post. It will arrive on Sunday night and I will be picking it up at 10:00AM next Wed. :D :D
Old Jun 6, 2002 | 01:48 AM
WildKarrde's Avatar
WildKarrde
From: My tolerance for stupidity is at an all time low.
WOO HOO!!!!! :D
It is finally arriving. I'm really happy for you, NoMercy. Enjoy.
:cool: :cheers:
To Snowmobile: Drivetrain by....
Old Jun 6, 2002 | 02:15 AM
Noggles's Avatar
Noggles
From: Adventure, excitement ... a Jedi craves not these things.
Cruise-In VII Veteran
Good luck. It's fun to follow your project, and thanks for the updates! :cheers:
Old Jun 6, 2002 | 05:30 AM
Snowman's Avatar
Snowman
Default Re: Snowmobile: Drivetrain by.... (Noggles)
Bill I am totally excited for you Bud! Have someone there taking video when it first comes off the boat and you fire her up. Remember the warmup period before you rev her up too much though!
Hey Buckmaster! I have a video of our (sorry MY) burnout and the actual race. Your friends were sure giving you a hard time during staging! :D I'll send the video's to you tonight. If someone could post 2 videos on your site and put the URL's in this thread, holler and I'll send them to you. :D
In other news:
My C5 is cleaned up and ready to go to MTI....mid-day tomorrow I'm thinking. I've located a front pair of HAL shocks so far. Anyone have an idea where I can pick up a full set or at least the rears? Email me please ASAP.
Snowman
[Modified by Snowman, 3:36 AM 6/6/2002]
Old Jun 6, 2002 | 07:55 AM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Glad to hear you're going to MTI!, You're in good hands there! Sounds like a good chance both our cars will be there at the same time.. :cheers:
Take the time and do it right, with all that HP, you'll need the tough stuff..
Tom
