Sometimes cars need a good high rpm run to blow out the carbon build up, and warming the cats is always smart. But it is the cam in this case. Too aggressive for an emissions test.
I did ET in GA for 15 years and the program there was basically a copy of the CA standards. Biggest diffence was that CA had more of an issue with CO and Ga had more of a issue with NOX. Mostly due to the different weather/climate conditions. I only have a quick second but since you are driving a stick car if you can induce a false vacumm source say like a small leak to the brake booster etc. it will take HC down in a second, on the flip side it will cause NOX to rise but it seems you have plenty of room there under the standard. My bet is the performance cats are not up to the GM cats or you would probably be OK. Good luck my friend !
And PS I know in the long run the vacuum leak will set off a lean code but if the "leak" is done right before the test it should not set before you walk out with a certificate lol. Also in GA just for the info we started to have to do visual's on the cats as the instructer of out ET class said that "some of thses guys with performance cars have figured out how to bypass the converter codes, something called simulaters" LOL so far behind the curve !
I agree with Bill Curlee your PCV system should be thoroughly checked. Did the previous owner have the air injection system tuned out? Have you checked for codes, history or otherwise?
This is from a post by Paul Wood from NC in a different thread:
"The AIR does nothing for performance and is only there to satisfy EPA emissions by adding "
'fresh air' to the exhaust prior to the CATs heating up."
Don't know if this would make a difference, but if it effects emissions I wouldn't leave any stone unturned. I would check the entire AIR system, especially to see if it has been tuned out.
Reason: spelling
Those high-flow cats are good for maybe a year. They'll flow much longer but won't be good enough to pass a sniffer. I keep a stock set of cats just for smog time.
plus, that rotten egg smell may be a good indication. I know with high-flow's I would get that but when subbing in the stockers it was clean, clean, clean...
