tire facing wrong direction?
Old Oct 22, 2012 | 11:44 AM
bstone1989's Avatar
bstone1989
Default tire facing wrong direction?
I had new wheels installed a couple months ago and I just noticed my rear tire was put on the wrong direction. It says this side inwards on it.. is this a big deal?
Old Oct 22, 2012 | 12:07 PM
corvettebob1's Avatar
corvettebob1
Is traction/handling wet or dry a big deal? Get it changed ASAP under normal driving you would never notice it but under an emergency situation do you want less grip on one tire?
Old Oct 22, 2012 | 12:09 PM
bstone1989's Avatar
bstone1989
Ok. I haven't noticed anything different, that's why I was asking.
Old Oct 22, 2012 | 12:25 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Yes, get it fixed asap from the same shop so its covered.
Old Oct 22, 2012 | 12:43 PM
lucky131969's Avatar
lucky131969
Not giving you a hard time, but obviously, the tire manufacturer thought it was a big deal.
Old Oct 22, 2012 | 01:00 PM
Birdman's Avatar
Birdman
I believe it usually has more to do with water evacuation from the treads being more effective one way than the other. Possibly increased grip, but more so the water. That's what I've inferred though, and not sourced.
Old Oct 22, 2012 | 01:13 PM
NukeC5's Avatar
NukeC5
Don't let them charge you for it. It was their mistake, and a sorry *** mistake coming from a tire shop.
Old Oct 22, 2012 | 01:28 PM
Trios's Avatar
Trios
Old Oct 22, 2012 | 01:32 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Usually the when the sidewall states this side in or this side out, it refers to an assymetrical tread design. It may or may not be directional also. If it is directional and assymetrical then the tire should only be used on one side of the car. They may have installed the wrong tire in that position.
For example, the late C4's came with Goodyear Eagle GSC's. They were assymetrical and directional with different sizes front and rear. The result was that each tire could only be used on one corner of the car. There were 4 different tires to make up a set.
Old Oct 22, 2012 | 02:15 PM
FRITZM's Avatar
FRITZM
Default Tire
Some tires, as mentioned previously, are marked as directional. If so, there might be an arrow following the word "rotation" somewhere on the sidewall which is an indication of the proper direction of forward motion.
Old Oct 22, 2012 | 11:01 PM
Mickeyrx70's Avatar
Mickeyrx70
You might consider checking with the tire manufacturer whether or not the tire is ruined. If the tire was made to roll in one direction & it's been used for two months rolling the opposite direction, it may affect performance.
Old Oct 23, 2012 | 09:20 AM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Instead of dispersing water to the sides, it sucks it in to the center of the tire. Not so funny.
It won't hurt the tire itself to turn backward, even if it is directional, but it sure won't help wet handling. Be extremely careful if you're caught in any rain.
To tire facing wrong direction?
