Thread locker or Anti-seize on headers?
Old Oct 24, 2012 | 06:15 PM
Triton170's Avatar
Triton170
Default Thread locker or Anti-seize on headers?
OK, I have done the search thing and still haven’t found a satisfactory answer. The question is what thread locker or anti-seize should I use on header bolts? The service manual for my car (2000 A4) says to use GM 12345493 or like equivalent. So I did extensive research and finally determined that Permatex #27200 (High Temp Red) is the equivalent of GM 12345493. Now the confusion. The Permatex stuff is a thread locker. Shouldn’t you use an anti-seize in the aluminum heads?
Old Oct 24, 2012 | 06:28 PM
lucky131969's Avatar
lucky131969
So what this really comes down to....is that you don't trust the service manual.
Old Oct 24, 2012 | 10:02 PM
kmetros's Avatar
kmetros
I'm with th OP. I put anti-seize on my head bolts too. There is no way I would put RED thread lock on them either.
Old Oct 24, 2012 | 10:07 PM
lucky131969
....and that's ok. If everyone owned, understood, and followed the service manual.....there would not be a tech section of this forum.
Old Oct 24, 2012 | 10:08 PM
Paul 75 L82's Avatar
Paul 75 L82
I've had lots of headers in the past. And have tried all different ways. Here's what I do. I use anti seize on the threads and I buy the expensive bolts that have the Allen head lock screw in the center of the head that locks the bolt in. I have never had any problems with those bolts.
Old Oct 25, 2012 | 08:13 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Personally, I think there's some confusion in terminology going on here. GM "red" thread locker is a fairly mild product, similar to a product called "Vibra-Tite". It's like a liquid lock washer.
Loctite "red" is some serious s**t, used for fasteners that you NEVER want to easily come apart.....
Old Oct 25, 2012 | 08:23 AM
lucky131969
I disagree. Do you think GM makes their own threadlocker in Detroit? Not only is Permatex interchangeable with the GM part number in the service manual............it's probably one in the same.
http://www.permatex.com/documents/td...tive/24026.pdf
Old Oct 25, 2012 | 08:45 AM
leadfoot4's Avatar
leadfoot4
OF COURSE, I know that GM doesn't make their own thread locker!! They don't make their own paint, tires, and a lot of other things too!! However, Permatex thread locker and Loctite thread both come in different formulations. I worked in the manufacturing sector for almost 40 years, and in my industry we used various liquid thread compounds for differing situations.
For instance, you want exhaust manifold/header bolts to remain tight, yet still be removable with a reasonable amount of force. You also want the threads to remain undamaged when those bolts are removed. That is why GM recommends THAT particular locking compound.
There is a different thread locking compound made by the LOCTITE Corporation, which also happens to be red, to differentiate it from the other products in THEIR product line, which creates a bond that is almost as strong as welding the bolt in place. In fact, in order to remove a fastener installed with this thread locker, the product instruction sheet recommends the use of a torch.
I highly doubt you'd want that product used on header bolts......
Old Oct 25, 2012 | 10:05 AM
lucky131969
Which is why I posted the link. The permatex TDS, specifically states it crosses to the GM number.
Old Oct 25, 2012 | 12:02 PM
dadaroo's Avatar
dadaroo
I would never put thread locker on bolts or studs into the head, especially Loctite "Red" which is for when you don't want to remove the fastener. I would use anti seize for removal ease and either use specially locking fasteners as discussed in the post or just check tightness once a year,etc. based on how many thermal cycles (heatup/cooldown) you go through.
Old Oct 27, 2012 | 01:17 AM
Tron Z's Avatar
Tron Z
That's just funny, I don't care who you are!
Old Oct 27, 2012 | 02:06 AM
ZeeOSix's Avatar
ZeeOSix
For Disassembly
1. Apply localized heat to nut or bolt to approximately 260°C
(500°F). Disassemble while hot.
A PIA ...
Old Oct 27, 2012 | 01:48 PM
lucky131969
Originally Posted by ZeeOSix
A PIA ...
Yep. It's almost like GM intended to install the exhaust manifolds once.
Old Oct 27, 2012 | 02:11 PM
ZeeOSix's Avatar
ZeeOSix
Speaking of ... if GM uses this thread lock from the factory (or are they really?), how are guys that remove the OEM manifolds finding it difficult to remove the bolts, or snapping off bolts if they don't know it should be heated up to 500 deg F before removal?
Old Oct 27, 2012 | 05:20 PM
lionelhutz's Avatar
lionelhutz
Mine came out with minimal effort. If there was thread locker, it wasn't doing squat. I put anti-seize on the bolts and re-installed. I really didn't care what the service manual stated.
Some comments in this thread border on stupidity. I suppose we should all blindly follow the factory for everything. After all, they manage to build perfect car without any defects. And they most certainly must have taken into account the use of aftermarket parts and the fact the cars might be modified when they wrote the manual.
Old Oct 28, 2012 | 08:03 AM
leadfoot4's Avatar
leadfoot4
Mine came off pretty easily, and since I was re-installing the OE manifolds, I cleaned the threads of the bolts and used anti-sieze for the re-installation.
Old Oct 28, 2012 | 09:21 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I don't put anything on the header bolts, never have, never will.
OEM hardware works best for headers, I have never seen an issue with any C5/6, well over 200 removal and installations
To Thread locker or Anti-seize on headers?
