Security light comes on during driving
Old Oct 27, 2012 | 12:01 AM
David426's Avatar
David426
Default Security light comes on during driving
The security light comes on during driving.. No codes.. Yes . I have done the by-pass 4 years ago.. Any ideas?
Old Oct 27, 2012 | 02:10 AM
ZeeOSix's Avatar
ZeeOSix
Resistive pellet on the key might be dirty and the BCM isn't reading it correctly. Burnish the metal tab on the key pellet with a soft pencil eraser and see what happens.
Old Oct 27, 2012 | 11:08 AM
David426's Avatar
David426
Thanks Zee.. You hit the nail on the head.. I had the same exact problem with my 99 C5,, years ago.. I don't know why it never dawned on me.. Forgot all about that event, until you brought it up.. I took a Q-tip and rubbing alcohol to the pellet.. Did the trick
Old Oct 27, 2012 | 01:17 PM
ZeeOSix's Avatar
ZeeOSix
... glad it worked.
I've found that using a soft pencil eraser on the metal strip on the pellet really works good. It actually burnishes off the oxidized top layer on the metal strip, which is something just rubbing alcohol won't remove.
To Security light comes on during driving
