Corvette bucking when pushing the pedal
Old Oct 31, 2012 | 02:03 PM
bovi's Avatar
bovi
Default Corvette bucking when pushing the pedal
Here's the story. Got my engine tuned 2 weeks ago ( 3k miles LS2 with vortech old-school s/c setup). I pushed the car hard for 3-4 runs on the street. Then i shifted the 5th gear and had a lack of power and check engine light came on flashing... I made about a mile without pressing the pedal or almost. i parked the car. Plugged my obd2 and saw it was cylinder 5 missfire. Put off the sparkplug, it was broke as f**k. The pin was almost soldered to the element, ceramic coating was missing part on it. Seems to me like a pre-ignition or something like this. I bought a new sparkplug and tried my best to gap it the 0.035'' like my tuner did on all others. Erase all codes. Then, i drove about 5 miles, car was running fine when daily driving, no engine code came up but at the moment im giving fuel more than 20% throttle, its bucking like a speedcut limiter.
Any ideas??? Damaged parts?? injector??
Thanks,
kevin
Old Oct 31, 2012 | 02:14 PM
cdkcorvette7's Avatar
cdkcorvette7
I'd take it back to the tuner and make them fix it...
Old Oct 31, 2012 | 02:19 PM
bovi's Avatar
bovi
Told me they dont give any warrant on that. Looks to me like the piston hut the sparkplug. 2 days after a tune, kinda strange no!!?!? Im pretty pissed off.
Old Oct 31, 2012 | 02:42 PM
lionelhutz's Avatar
lionelhutz
Pistons don't just hit the proper spark plugs. Maybe a broken piece of the piston hit the plug.
Try to find someone with a bore scope and take a look into the cylinder. You might be pulling the intake and head in your near future.
Old Oct 31, 2012 | 02:49 PM
bovi's Avatar
bovi
Theres a little kuckling sound at idle... maybe a bent rod i guess...
Old Oct 31, 2012 | 03:16 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You my friend have a serious Cyl 5 issue. Look at the valve spring and see if its broken! I agree. Time to do some inside the cylinder looking. Home Depot sells a nice and affordable bore scope.
Give that a try!
To Corvette bucking when pushing the pedal
