Isn't it kind of pointless to "read plugs" on anythign but a dedicated drag car? If you make one hit, coast back to the pits, and pull them out, then yes it could tell you a lot of great information. After you DD it at 14.7 and light load, wouldn't the plug be seeing so many varying conditions that it would be unreadable, besides extreme cases?
(These are not rhetorical questions. I am genuinely asking.)
Jack
Jack,
You are correct for reading plugs when the goal is to find the full load heat range. Can be done on the dyno as well.
Tblu92 is correct too.
That's why I said +/- 1 range from ideal is fine for driving around.
In my car, I've found it likes 12.0-12.2:1 at peak torque (4800-5000).....it's NA.
Didn't get far enough with the tuning to change the power enrichment at peak power which seems to be right around 6300.
I know if we got it too lean at peak torque, I got knock retard.
Of course different combos are different. We are striving to give the engine what it wants, the numbers will fall wherey will.
We are tuning on the dragstrip...so it takes a lot of runs. Just ran out of summer!
Youre right Ron, every combo is different. My LS3 is making peak torque around 4500-4600rpm, almost 460ftlbs cam only. One of the highest Ive seen for the cam and mods I have. I have to look back at the log to see where the afr is at that rpm but its probably low to mid 12's then leans out to 12.8 up top, shift point is at 6500.
Jack
YES the " art" of reading plugs is strictly for WOT tuning--The details i gave were strictly for that and yes reading plugs for P/T tuning is pointless because the timing can vary from -10* to + 45* and th AFR can boounce all over the place as the 02's coorect the fuel via the fuel trims
You can still tell from the general conditions of a plug how the car is running though. I guess thats more what I meant when I said "reading" the plugs. Wot is what really matter though, that when you see the most load and when stuff breaks.
It is important to be aware of ethanol content in fuel. My guess is, that if you really are seeing peak power at that low of an AFR, that there is a decent amount of ethanol in the equation.
Old school racer here--- Can't really tell by these photos --however this is how I was taught a 100 years ago
1st to read timing on the plug:
You go to the plug strap--and look for-- where the color changes on the strap--very difficult to read old plugs-- best is to use new ones---I like to use NGK plugs as the cadium plating is there to burn off cleanly when 1st ran and it's very easy to see where the color changes-----
Ideally you want the color change to be on the CURVE of the starp
IF the color change is more towards the strap end--Needs more timing
IF the color change goes down towards or into the threads--too much timing
As far a fuel goes (rich/lean) you have to get a magnifying glass and look into the plug's core----
Again very difficult to read with any plug that has been run much
Ideally you would want some color to grow up from the bottom of the core porcelain apprx. 1/16" to 2/16"
More than 2/16" would make it on the RICH side
Less than 1/16" woud make it on the LEAN side
NO color would be VERY LEAN
Fuel additives make the plugs inaccurate to read this way beacuse the additives change the fuel burn
Best is to mix some race gas with premium fuel to raise octane
Switch that? I question this because I (also old-school racer) have always adusted a/f with the burn line on the side electrode and timing with coloration on the center insulator.
Reading plugs is definitely becoming a lost skill!
Took a short drive, gave it a quick wot here n there. Now the ground straps are all white. Wtf? Porcelain is clean, no specks.
By the way i was taught--The color change here in just barely visable near the threads which would indicate TOO MUCH timing
Can't see the center electrode down inside to see AFR
Could it be that my old spark plugs were ok, heat range wise, but the octane booster that was still in the tank when I first ran the motor turned them orange? And...now the new stock heat range plugs are too hot?
That's what I'd say. I always considered a light cinnamon brown color on the center electrode and ground lug to be an indication of proper heat range. Try some new plugs of the heat range you used before, but without any octane booster.
Thanks Z. I just ordered some Tr6's at autozone. I'll get them this afternoon. Those are the same heat range as the autolite 103 but ngk seems more popular with LS motors. Hope it helps.
I started to think it may be the plating burning off as well. Anyway I figured the car ran good all this time with colder plugs so I threw the tr6's on. Im just think of when I go to the track and Im beating on the car with higher temps a cooler plug will help avoid any detonation.
Well guys heres what I found....first of all, the whitish color is from the plating on the tip. The nickel coating gives it that color. I hadnt seen that before with my autolites because they have a black coating, not nickel. What I did go off was the color band you can see on the ground strap. With the stock heat range they were close to the base, indicating it was on the hot side. With the ngk tr6's, the mark is now closer to the middle of the strap indicating a proper heat range. I noticed the car idles very well with the ngk's and seems to rev up smoother. Also less exhaust popping on decel. Only thing now is, I did a 3rd gear wot test on the fwy today while data logging. I figured it was warm and if I would see any detonation it would be then. I got no knock and the car felt great BUT the timing at wot was 31.9* when I had tuned it at 28*. Im guessing the ecu sees no knock and is advancing the timing? Iat' were low, 90's*, but I have that table tuned out anyway.
Ill need to go back and look at the file, its on my friends laptop. I thought they were the same but im not sure. I guess as long as there is no knock I should be alright.
