The pics are Autolite 103's I had in my cam only LS3. I used them in my old high compression LS1 build but I think they're too cold for this setup (they're same as TR6's) I switched to Champion Copper 408's which are stock heat range plugs for an LS3. So do the plugs look too cold for you guys as well? The plugs were on the car about 1500 miles since I put the motor together. Ive since adjusted the timing (less of it, 28* wot) and fuel, 12.8-13.0afr wot. I don't drive long distances and I think the cooler weather as well made it worse, cold plugs couldn't burn off all the carbon.
Some info,
LS3, stock block and heads
TSP 231/236 114lsa
LS1 coils with Taylor 8.5mm LS3 plug wires
I was seeing 28* timing at wot so I know the ecu wasnt pulling any timing and I didnt see any knock retard either. No blowby, doesnt use oil and oil looks clean. Plugs were dry also when I pulled them.
The carbon may be from too cold of plugs, but as for the orange burnt areas of the porcelain, are you running any additives allot? Adding octane booster etc? From what I understand, that color can come from too much additives.
Monitor you new plugs though and maybe it will just have been a heat range issue. I'm sure you plan to do that anyway.
Yeah, once it put some miles on the new plugs Ill check them out. I havent ran any additives but the car still had some e85 fuel in it when I first put the motor in it. I did use an octane booster once when I first ran it at the track. Not sure if that would do it. Ive done more tuning since then.
We have all tried the booster! That orange simply won't burn off.
I don't think you can make a real good determination about heat range from those plugs. In fact, for just driving around (not racing or going WOT all the time) heat range isn't real critical.
I'd put a new set in and run em for awhile and have a look. That's why I bought the NGK TR5 and TR6 plugs, cheap to play with.
Others may have a different view.
Do you log with HPT or EFI live? Shows detonation right away.......
I have a data logger app and I used my friends hptuners. It showed a lil knock once in a while when it was warm at first. That was the old tune from my 12:1cr ls1 with a big cam and i used the same type of plugs. I lowered the timing and adjusted the afr. I havent seen knock but on cold starts the idle would be a lil rough for a sec. I pulled the plugs and they were all that dark brown orange color. The 103's are on the cold side so I figured that for a basically stock motor with a mild cam I would be ok with stock heat range, especially now that the weather is cooler.
With new plugs the car started and idled very nicely right off the bat. The booster i tried was a few months ago already, like august. I wouldve thought it wouldve burned off but that stuff bakes on hard.
Ya it really discolors them, but I dont think its an issue. Your new set should stay clean looking though if your tuned right. Its a good indication of a well tuned car.
That brown color shows up on plugs with race gas too. I've used CAM2/Sunoco unleaded racing gas (100 or 104 depending on the source) from Speedway gas stations and race tracks in my area.
Do you change the gap at all? Just curious if wider gaps are ever used with suitable ignition modifications. I understand it's more work on the ignition to jump the wider gap. But wider plug gaps are also sometimes useful to make more power? Just asking. Not say this is something you should do
Yeqh, on my old setup my plugs would always look new even after a few months of driving and racing. Thats why I was surprised by the color this last time. Ill give the new plugs a nice little run and then check them out.
The 103's i ran the gap that they came with. Cant remember, .40-.45 i think.
Old school racer here--- Can't really tell by these photos --however this is how I was taught a 100 years ago
1st to read timing on the plug:
You go to the plug strap--and look for-- where the color changes on the strap--very difficult to read old plugs-- best is to use new ones---I like to use NGK plugs as the cadium plating is there to burn off cleanly when 1st ran and it's very easy to see where the color changes-----
Ideally you want the color change to be on the CURVE of the starp
IF the color change is more towards the strap end--Needs more timing
IF the color change goes down towards or into the threads--too much timing
As far a fuel goes (rich/lean) you have to get a magnifying glass and look into the plug's core----
Again very difficult to read with any plug that has been run much
Ideally you would want some color to grow up from the bottom of the core porcelain apprx. 1/16" to 2/16"
More than 2/16" would make it on the RICH side
Less than 1/16" woud make it on the LEAN side
NO color would be VERY LEAN
Fuel additives make the plugs inaccurate to read this way beacuse the additives change the fuel burn
Best is to mix some race gas with premium fuel to raise octane
Isn't it kind of pointless to "read plugs" on anythign but a dedicated drag car? If you make one hit, coast back to the pits, and pull them out, then yes it could tell you a lot of great information. After you DD it at 14.7 and light load, wouldn't the plug be seeing so many varying conditions that it would be unreadable, besides extreme cases?
(These are not rhetorical questions. I am genuinely asking.)
Jack
To read them for true tuning reasons then yes, it best to read new plugs right after wot pass and follow the steps like in the post before yours. Im speaking more in general. You can tell if a car is a bit rich, lean or if it has the correct heat range plugs by some general discolorations of physical signs.
I have found that most LS motors make peak power with 12.8-13.0afr. Most factory tunes are rich at around 12.4-12.6afr. I see no knock on my data logger.
