Techron Does It Again!
Old Nov 2, 2012 | 07:53 AM
GEMcLean's Avatar
GEMcLean
Default Techron Does It Again!
Last Sunday, I filled the fuel tank, started the engine and the guage read EMPTY!
Checked codes and got the dreaded P2068.
Added 20 oz. of Techron to tank.
Two days later, all is well!
Another testimony that Techron works.
Old Nov 2, 2012 | 10:39 AM
c5chines's Avatar
c5chines
But from what I was told (and my own experience) you add the techron to the empty tank and then fill up or it won't get into both tanks.
Old Nov 2, 2012 | 04:54 PM
FKING1's Avatar
FKING1
Worked for me with same gage problem.
Old Nov 2, 2012 | 07:07 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Yep fixed my issue 5 years ago. It hasn't happened again.
Old Nov 2, 2012 | 08:15 PM
Radicaltimes's Avatar
Radicaltimes
When I had this problem all I had to do is shut the car off and then restart. I did add Techron after the problem. I added it for the next couple tank fulls.
Old Nov 2, 2012 | 08:53 PM
GEMcLean's Avatar
GEMcLean
P.S. Advance Auto has it on sale right now. 20 oz for 12.99, second bottle for $1.00.
Old Nov 2, 2012 | 11:23 PM
bobby777's Avatar
bobby777
Seafoam_ Damm good sfuff--
Old Nov 3, 2012 | 05:51 AM
strand rider's Avatar
strand rider
seafoam what? they sell injector cleaner, engine cleaner, I don't know which one approximates Techtron so I just buy Techtron. It would be nice to know the answer so that when it goes on sale I could get some.
Plus it might help to change things up. I run only Chevron, and my gas gauge flips to empty if i am in a steady cruse at about half tank. It's happened twice, and only in that situation. I think something with the tanks when they change over is whacked.
I thought a few slugs of techtron erased the problem from my life, but it happened for the second time last weekend. The last time it didn't reset when I started the car again, as expected. I had to fill the tank to get the sender signal back .
Old Nov 3, 2012 | 06:48 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
we have been putting Techron in her 02 for the past month due to an on again off again misreading fuel gage....
gage reads E or drops to E whenever it wants to....comes back for a bit then goes to E again....also fill the car up and it only goes to 7/8
Techron hasn't helped a bit
Old Nov 3, 2012 | 06:54 AM
yellowvette837's Avatar
yellowvette837
St. Jude Donor '03 thru'19
Tampa Events Princess
2015 C6 of Year Finalist
I Believe In The Beer Fairy
I need to stop to get gas, because I cleared the trip odometer clearing the Low Fuel message for the second time this morning.
Old Nov 3, 2012 | 07:53 AM
CactusCat's Avatar
CactusCat
Just a brief question out of my own curiosity. Are any of you guys running 100% pure gas? Or is everyone using the E-10 stuff?
Old Nov 3, 2012 | 10:17 AM
c5chines's Avatar
c5chines
In Michigan,there isn't much choice for avoiding the ethanol.
Old Nov 3, 2012 | 10:43 AM
RonSSNova's Avatar
RonSSNova
Makes sense to me, I've never found any "pour it in" magic elixer to fix anything.
Have no clue why the OP would conclude that it worked in 2 days..........
Old Nov 3, 2012 | 11:39 AM
pewter99's Avatar
pewter99
legend has it that Techron fixes the sticking gas gage....not sure if its true..used it in the past and the gage started working again....Techron or coincidence? who knows with these flaky gages
Old Nov 3, 2012 | 09:53 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
read the back of the sea foam can.
Old Nov 4, 2012 | 12:12 AM
fishbust's Avatar
fishbust
Being a boater, seafoam is very popular with outboard motor owners, especially going way back before metering oil injection. Very good stuff for clearing up gunk and especially breaking up carbon buildup in the combustion chamber.
Old Nov 4, 2012 | 06:00 AM
JMBLOWNWS6's Avatar
JMBLOWNWS6
My car had the solder joint coming off into the sender wire. Was hanging on by 1 strand. Re soldered it and problem is gone.
To Techron Does It Again!
Old Nov 4, 2012 | 07:14 AM
C5Natie's Avatar
C5Natie
Yeah, hard to tell but Ive only had my gauge go to E once a few years ago. After a search on the forum I read that Techron was the answer. I cleared all dtc's and poured in a bottle. Hasnt happened again. I gotta give Techron the win but who knows. I use Chevron gas as much as I can.
Old Nov 4, 2012 | 11:49 AM
sami85L98's Avatar
sami85L98
Although techron not available in Canada may be but atleast in Toronto, so got 2 bottles in buffalo, gas needle came back to life...but eventually after a week same thing gauge never worked even to date after puring 2 bottles.
Hit and miss i guess, but will take the fuel pump out and check senders unit, while trhe car sleeps for winter.
Old Nov 4, 2012 | 05:10 PM
FKING1's Avatar
FKING1
All Michigan gas is 10% Eth.
