Modifying compter rev limit/tire size correction.
Old Jun 6, 2002 | 12:30 PM
Phil97SVT's Avatar
Phil97SVT
Default Modifying compter rev limit/tire size correction.
What is the cheapest way to raise the rev limit as well as correct for using a larger or smaller sized tire/gear in a C5? Thanks in advance.
Phillip :cheers:
Old Jun 6, 2002 | 11:12 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Modifying compter rev limit/tire size correction. (Phil97SVT)
ttt
Old Jun 6, 2002 | 11:35 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
I don't think you have any options outside of PCM programming. In terms of cheapest outright, a used HPP3 is probably the winner. It's less viable if you're changing to a gearset not offered for your configuration.
Old Jun 6, 2002 | 11:59 PM
AP's Avatar
AP
Default Re: Modifying compter rev limit/tire size correction. (ToplessTexan)
Even a new HPP3 would be cheaper than most ... and it will change the tire size to any size ... so if yhou switch again in the future it will be useful ... I used to run large tires in the summer and Run-Flats in the fall (due to weather) ... and the HPP3 was great ... I just flashed it with the new sizes every time I switched tires ...
To Modifying compter rev limit/tire size correction.
