Head gaskets and bolts?
Old Jun 6, 2002 | 01:32 PM
Phil97SVT's Avatar
Phil97SVT
Default Head gaskets and bolts?
When I swap my heads over to the new ones which head gaskets and bolts should I use? Do I need any of the other gaskets or special tools when completing a head and cam install?
Thanks in advance!
Phillip :D
Old Jun 6, 2002 | 11:13 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Head gaskets and bolts? (Phil97SVT)
ttt
Old Jun 7, 2002 | 01:20 AM
Operations's Avatar
Operations
There is a lot about this at LS1tech.com
I have a some of the same questions.
Some are talking about getting your head gaskets from NAPA, they use the gasket as OEM but wrapped diffrent. check it out.
The head bolts are not Torque-to-yield type. Even though for a good while GM promoted replacing the head bolts if you pulled the heads.
My buddy Steve, at our local Chevy dealership who is the corvette mech. said he read a bulletin from GM that all warranty work that required pulling the heads that they were not to replace the bolts, but to clean them up and reuse them.
Sounds like GM don't mind us wasting money, but they don't want to.
:mad
Old Jun 7, 2002 | 01:54 AM
C5Noir's Avatar
C5Noir
This all the site you need: http://ls1.fbody.com
Old Jun 7, 2002 | 02:11 AM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
GM has done it to us again. The right side head gasket has been discontinued. You have to buy the top end set that retails for $260. You can still buy a left side head gasket though????
Old Jun 8, 2002 | 01:22 AM
Operations's Avatar
Operations
Default Re: Head gaskets and bolts? (Andy@AandACorvette)
You can get both gaskets from NAPA. They will have to specialy order them from Clevite/Victor. I ordered mine today. I paid 13.85 each.
If anyone needs the part numbers, I have them written down at work.
Just let me know.
Old Jun 8, 2002 | 02:41 AM
evil-1's Avatar
evil-1
Default Re: Head gaskets and bolts? (Operations)
Gaskets from NAPA,then go the extra bucks (225.00) and put in ARP studs instead of head bolts......... :cheers:
Old Jun 8, 2002 | 06:36 PM
Redline Motorsports's Avatar
Redline Motorsports
Default Re: Head gaskets and bolts? (evil-1)
If you use head studs you will have a hard time installing the heads in the car.
Any bolt that long is most certainly a "torque to yield" fastener! If ARP rod bolts stretch these bolts will definately will!
Make sure when you use a new factory bolt that you clean the orange crap off the thread and replace it with a good sealer. That material will cause the head bolt to reach torque before its ready.
The stock head gaskets (GM) are fine for most applications. If you want more compression you can go to a .030" thick steel shim gasket.
The bolts are cheap......why screw around with it!
To Head gaskets and bolts?
