We offer a special during the cold months to help people get ready for the spring. Here is what we have to offer.
Comp Cam of choice- We custom spec from our testing done throughout the years.
Brian Tooley dual springs with titanium retainers, good for .660 lift
Hardened pushrods custom measured for setup
C5R timing chain
NGK spark plugs
mobile 1 0w-40 oil and GM filter
check/port stock oil pump
160 t-stat
New GM gaskets
port stock TB if not done already
Full install of all parts
Full street tune in Speed density,then closed loop
Full dyno tune
price includes all taxes
$2334.82 -C5/C6 Vettes
Some added cost for supercharged,turbo,nitrous cars depending on setup.
Problem with the A4 is the cam has to be limited to keep idle at 750rpm and under.
I would suggest longtube headers and a stall converter before a Cam for your car.
