98 Miss
Old Nov 8, 2012 | 01:09 PM
aobrien14's Avatar
aobrien14
Default 98 Miss
Hi Guys,
Background: 98 coupe w/74000 miles. No internal mods, but the typical bolt-on's (intake, headers, corsa exhaust, etc.). Car has had mods for several thousand miles without issue.
Symptoms: No codes being thrown. Car struggles to stay running (but does), especially after coming off the highway at sustained cruising speed in the 70-75 mph range. Runs PERFECTLY fine under heavy throttle or even WOT. Under light acceleration, it feel like there is a slight miss. Mechanic says that scanner is showing big timing adjustments being made after coming off the highway.
Constructive thoughts/suggestions more than welcome. Vacuum leak?
Andy
Old Nov 9, 2012 | 03:53 PM
SinghZvette's Avatar
SinghZvette
Default Hope this helps.
Mine is a 98 C5 coupe MN6 with 94k miles and had the same problem this summer but it was missing at lower rpms and high gear. Long story short it turned out to be a lose spark plug wire. I must have bumped it while cleaning the engine bay, the neat-freak that I am. I ended up replacing all of the spark plugs and got GM performance spark plug wires while at it and shes been running smooth since then.
Old Nov 9, 2012 | 04:05 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds exactly like the symptoms of a vacuum leak or your getting UN METERED air into the engine.
Check ALL (and I mean every) vacuum line/s. Your PCV system is well known to deteroriate and leak. It runs arounf the back of the engine behind the intake manifold:
You can see the hoses and rubber coupler in this pic:
Carefully check the ducting between the MAF and the TB. It MUST be 100% SEALED AND CAN NOT LEAK AIR.
Have you ever cleaned the MAF and TB????
If not, I would do that also.. Purchase some MAF cleaner and spray it clean.
Let us know how you make out.
BC
Old Nov 9, 2012 | 06:01 PM
aobrien14's Avatar
aobrien14
Default 98 Miss
Thanks for the comments guys.
Turned out to be fuel related. Added some HEET to the fuel, ran it 20-30 miles and issue is completely gone.
However, your suggestions re MAF and TB cleaning are well founded, appreciated, and will be acted on.
To 98 Miss
