Plug wires and plugs?
First question is about plug wire resistance. I have the original set of plug wires and a set of 2 year old GM "red" plug wires currently on the engine. I was checking wire resistance with an ohm meter to see if I could find a bad wire. (code 1053 and 1153 showed up yesterday). The original gm wires had and average reading of 360. ohms. The wires currently on the engine have an average ohm reading of .799 ohms. All wires were consistant for each set but that is a big difference between two sets of wires that both worked well on the engine.
Why the big difference in reading and which set of wires would you use?
I just ordered a set of NGK plugs. Local parts store lookup calls for
TR51X. Seems like people on this forum are installing the TR55 plug. Why the difference in what the "book" calls for and what is being used by many forum members?
www.gmpartshouse.com
Our LS1/6 wires are,, what, 6-8" long???
Reasitance of a sparkplug wire has ZERO effect on performance. My MAGNICORES are 2000 ohms and I am at 450 RWHP.
I just switched to the GM Red wires and there really wasnt any difference at all.
The GM Red wires have very high quality hardware, fit excellent and you will not have any connection issues.
Dont let claims of LOWEST resistance wires egg you into purchasing high dollar wires .. There is ZERO HP to be gained in spark plug wires fancy coils or fancy high dollar plugs.
GM Performance Red Wires, ACDelco Professional Iridium Spark Plugs and the stock coils will NOT fail you. Like I stated, thats what I have and it supports 450 RWHP without fail.
100% The "We have less resistance than the other leading brand" claim, is pure marketing hocum. Period. Do NOT buy into that nonsense.
I like Magnecore KV85 due to quality of materials, construction and termination and that's what I have now. The GM performance reds are also a decent wire as well but, unfortunately for me, several were destroyed by the guy installing my engine. He didn't want to take the time to be careful. Why would he? It isn't his car.
