1-7/8 or 1-3/4 Headers
Old Nov 10, 2012 | 01:09 PM
David426's Avatar
David426
Default 1-7/8 or 1-3/4 Headers
What size headers would be best with a 224/230 .581 lift cam.. Stock 243 heads?
Old Nov 10, 2012 | 01:56 PM
vettenuts's Avatar
vettenuts
Personally, if I couldn't have my current set of headers (no longer made) I would go with 1-7/8. My tuner has not seen major loss of low end and only benefit on the high end.
Old Nov 10, 2012 | 04:31 PM
Rx7Rob's Avatar
Rx7Rob
I recently talked to ARH and Kooks, as well as my tuner about the size of primaries. All said 1-3/4 would work with my planned mods but they haven't seen any loss from going with 1-7/8.
Old Nov 10, 2012 | 05:13 PM
Blk_'01_Z06's Avatar
Blk_'01_Z06
I went with 1 7/8 ARH on my 01Z, PM Randy @ Ragin Racin, he's a forum vendor. He'll get you a great deal.
Old Nov 10, 2012 | 05:21 PM
NukeC5's Avatar
NukeC5
1-7/8 would be good. I think the cam is good enough to make use of the wider primaries. Might pick up a lot more horse than torque, but I think its worth it.
Old Nov 10, 2012 | 05:45 PM
sfc rick's Avatar
sfc rick
Unless you have big cubes or high flowing heads, 1 3/4 are perfect.
Save your beans and spend what's left on some other goodie you want.
Old Nov 10, 2012 | 06:22 PM
David426's Avatar
David426
Thats what I orginally thought too.. Come to find out There is only a $24.00 difference in price...
Old Nov 11, 2012 | 01:10 PM
MT0911's Avatar
MT0911
1 3/4 will work perfect in most cases. 1 7/8 are great if you plan on putting down some big power one day. You should be fine both ways in your current form. It's really your decision.
Old Nov 11, 2012 | 01:41 PM
RonSSNova's Avatar
RonSSNova
It would be interesting to know whether the dimension is measured ID or OD.
I have XS power on my car. The tubes measure 1.86" OD. Maybe they are real thick? Advertised as 1 3/4 of course.
I have another set of Bassani Try Y to try....maybe.....also advertised as 1 3/4", and they measure 1.75" od.
Food for thought.
Perhaps some of you fellows could grab the calipers and measure what is on your car?
Ron
Old Nov 11, 2012 | 03:36 PM
Blk_'01_Z06
On the AR 1 7/8 I bought, I actually measured them when I got them, as they looked a little off. All eight tubes were 1 7/8 Inside diameter, like 2.15 outside diameter.
Old Nov 11, 2012 | 03:50 PM
Rx7Rob's Avatar
Rx7Rob
I believe most are using 18g primaries = ~0.05"
Old Nov 11, 2012 | 11:16 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
LG's tested both the 1 3/4 and 1 7/8 and said on a stock cube 346 the 1 3/4 pulled more torque.
I spoke with Anthony at LG's a year ago about that.
I'm running 1 3/4 and very happy with my results.
On a bigger cube motor you would benefit from the 1 7/8.
Why don't you ask me this stuff Dave ?
Toque
Old Nov 12, 2012 | 05:04 PM
z06scentair's Avatar
z06scentair
Food for thought.
Ron
Stainless Works 1 7/8" measured 1.876" on the OD of the tube.
Old Nov 13, 2012 | 12:30 AM
RonSSNova's Avatar
RonSSNova
Interesting.
The XS power may be tweeners!
To 1-7/8 or 1-3/4 Headers
