2003 C5 Intermittent no start...
Old Nov 12, 2012 | 02:37 AM
2003Convert's Avatar
2003Convert
Default 2003 C5 Intermittent no start...
2003 convertible auto with occasional stall and intermittent no start. Sometimes when I start it, it stalls after 20 or 30 seconds, then restarts fine and runs great. Last week it did this and wouldn't restart. After flat bedding it home, same problem the next day. Plenty of fuel and spark. Left it in the garage for the hurricane for a week. Started it today, it stalled once and ran great all day! Crank sensor maybe? HELP!
Old Nov 12, 2012 | 06:34 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When you say "INTERMITTENT NO START" do you mean that the starter will not crank the engine over OR the starter cranks but the engine will not fire and run????????
The DTCs will tell us a LOT!
Old Nov 12, 2012 | 11:26 AM
2003Convert
As soon as codes pop I'll post 'em...no codes yet. I have a small code reader and a Snap On Modis scanner. Car always cranks....not a starter problem.
Old Nov 12, 2012 | 12:22 PM
2003Convert
Here are all the codes present:
C1278H
U1000H
U1096H
U1255H
U1064H
U1016H
Old Nov 12, 2012 | 12:51 PM
2003Convert
Thanks a lot...keep in mind that as of now it starts ans runs like a top, never stalls or no start. Quick ques...if the crank sensor was causing the no start, would I still have spark? I had spark when the car wouldn't start...
Old Nov 12, 2012 | 01:05 PM
2003Convert
Just found a piece of paper in the car from the night I had it towed....more codes:
B2244H
B2262H
B2264H
B2284H
B2283H
B2283H
B2285H
P1431HC
B2212H
B446HC ?
Old Nov 12, 2012 | 02:03 PM
2003Convert
Sorry about all the updates...I cleared the codes and got the problem to come back. Now I have:
P0335HC
U1000H
Old Nov 12, 2012 | 02:41 PM
2003Convert
Thank you so much for the info and the fast replies...much appreciated Bill. I'll keep you posted.
Old Nov 12, 2012 | 02:44 PM
2003Convert
BTW...if I disconnect the battery will I have a problem with the blend doors on the heat? The passenger side is stuck on hot, which I can deal with, but the drivers side works fine. I don't wanna mess it up. Like I said, I can deal with it the way it is. Thanks.
Old Nov 12, 2012 | 03:10 PM
2003Convert
Ok. Thanks. I thought went you disconnect the battery it has to actuators have to relearn...
Old Nov 21, 2012 | 09:31 AM
2003Convert
Thanks to all for the support...crank sensor installed, relearn compliments of my Snap On MODIS, 4.5 hours of running in the driveway, and put 30 miles on the car so far. I think it's fixed! Snapped one stud on the exhaust manifold on each side. Buttoned it up with no leaks, but need to get new studs. Anywhere in particular you recommend for "factory style" manifold studs?
To 2003 C5 Intermittent no start...
