alternator advice
Old Nov 13, 2012 | 03:44 PM
WHoisu05's Avatar
WHoisu05
Default alternator advice
have a c5 z and the alternator jus went out would you guys just get another ac delco or is there something better. The car has a built top end and a pretty mean sound system so would i benefit from one that pushes more amps?
Old Nov 13, 2012 | 04:07 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The OEM alternator should handle anything that you can throw at it. How many AMPS do you think that your stereo draws power wise??
You have to be careful what alternator that you try to replace yours with. The alternator is PCM monitored and if you get one that isn’t, it will give you a charging system fault message all the time.
BC
Old Nov 13, 2012 | 04:08 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What made you think that yours was defective?
Old Nov 13, 2012 | 04:15 PM
WHoisu05's Avatar
WHoisu05
Car stared last week with low voltage 11 then this past week at idle would jump from 13 to 14.8 once i started driving it would go to 18 and every dash light would flash and turn off plus it just failed the alternator test at autozone
Old Nov 13, 2012 | 04:34 PM
WHoisu05's Avatar
WHoisu05
And I think the amp is 1200watts and has focals all around the car
Old Nov 13, 2012 | 05:55 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds just like you have a bad connection at the starter solenoid. TRUST ME! If those wires are loose or damaged,, you are seeing what happens. Try that first
Old Nov 13, 2012 | 06:03 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
1200 WATTS is not AMPS.
If I remember correctly, your alternator is 140 amps at full tilt. If you use WATTS LAW (P= I X E ) P=Power 1200W,, I= Current (which is the unknown) and E= Voltage use 14.0 VDC
1200W divided by 14.0 VDC = 86 AMPS (and that is NOT a constant draw) Thats a momentary peak draw. Trust me,, you have PLENTY alternator output.
BC
Old Nov 14, 2012 | 04:31 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
BC
Good advice yet once again Bill.
If I may pick your brain sir....
Is their any math to figure out what an amplifier is truly putting out in both wattage and amps? In other words...say we have 2 amplifiers, one is 1000 wrms and the other 300 wrms. That would total 1300 wrms. Now the fuses on the amplifiers are 100 amps and 60 amps. These are not pulling 160 amps at full max output...are they? That just wouldn't seem right for common sense reasons being your alternator would be overpowered and you technically I would think would blow the fuses at max draw.
Curious....
Old Nov 14, 2012 | 04:44 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Im pretty good in a LOT of things but modern day stereo stuff is NOT one of them.. Im positive that if you asked the same question in the stereo section, the brains would know! Those stereo guy know their stuff WELL!
When you figure out the answer, let us know and also let us know what caused your issue.
BC
Old Nov 14, 2012 | 05:58 PM
WHoisu05's Avatar
WHoisu05
alright took the alternator to orileys to get a second opinion and it passed both times so guess autozone is full of S&^T... i'll look at the starter i just had the heads resurfaced a few months back so maybe the starter wasnt tightened back right... Also bill do you think it could be any relays or a fuse?
Old Nov 14, 2012 | 06:26 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NO and maybe!!
Heres your schematic.. There are fuses BUT,, they are FUSABLE LINKS in the wire or should I say at the end of the wire. You can see them in the pictures of the starter:
Alternator:
Starter
Old Nov 16, 2012 | 03:00 PM
WHoisu05's Avatar
WHoisu05
so bill after checking every thing you've told me i found the starter wires to be loose i can move them around just have to removed the header and get it done now
Old Nov 16, 2012 | 03:08 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I had a strange feeling that was what you were going to find. Be careful when tightening it.
Clean it and use the correct torque and be care not to break the bakalite starter insulator.
BC
Old Nov 16, 2012 | 03:28 PM
3boystoys's Avatar
3boystoys
Most GOOD stereo's have BIG external capacitors to take the load off the charging systems under heavy loads. The amps should have max current on them somewhere but power is generally Voltage * Current = Power but in an application like AC or Audio it's a little more complex but all you care about is MAX current draw.
http://en.wikipedia.org/wiki/Audio_power
Old Nov 16, 2012 | 05:35 PM
WHoisu05's Avatar
WHoisu05
bill the bolt just fell off from the starter its the one on the bottom with 3 wires... all i did was put a wrench on it and it started to wiggle then i grabbed it and it just came loose from the starter
Old Nov 16, 2012 | 06:05 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Time for a new solenoid or a new /used starter;;
Old Nov 16, 2012 | 06:15 PM
WHoisu05's Avatar
WHoisu05
is this a common thing on a 10 yr old vette? id rather just buy a whole new starter unless you tihnk the solend.. would be a easier less costly repair
To alternator advice
Old Nov 16, 2012 | 06:27 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It is NOT common on a properly tightened/clean connection.. However,,, for what ever reason,, Yours became loose. When you have a loose dirty connection in a low voltage HIGH CURRENT circuit like the STARTER,, that loose joint make LOTS of heat.
SO,, you cooked your connection
You have several options. Replace the solenoid ($50), reman starter approx $140. New starter approx $300.
All options require starter removal.
NOTE. MAKE SURE that you get the proper starter bolt torque and TORQUE it to the correct specs.
If you dont,,, this can happen:
BC
Bill
Old Nov 17, 2012 | 01:09 AM
Really good information - thanks.
Old Nov 17, 2012 | 03:03 PM
WHoisu05's Avatar
WHoisu05
Would you know where to look for a replacement solenoid? I've searched the net but can't seem to find anything
