Check Engine Light and code
Old Nov 13, 2012 | 05:40 PM
Evil Oil Apologist's Avatar
Evil Oil Apologist
Default Check Engine Light and code
Getting a 10-PCM, P0154 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 code from the DIC.
However, I have LG Long Tube Headers. The tuners did the usual hardwire to ignore the back two sensors and dyno tuned the puter. The set up has run just fine for a year and a half.
Do you think it's a hardwire or software issue?
Old Nov 13, 2012 | 06:02 PM
ZeeOSix's Avatar
ZeeOSix
Start with the easy stuff. Check wiring and plugs first.
Old Nov 14, 2012 | 09:22 AM
Evil Oil Apologist
Easy stuff fine. Looks like a O2 sensor has given up the ghost. The setup still has the first set of sensors. Easy fix.
To Check Engine Light and code
