Recomendations for a OBDII scanner.
Old Nov 15, 2012 | 10:44 AM
StratTone's Avatar
StratTone
Default Recomendations for a OBDII scanner.
I'm looking for a pretty decent scanner to add to my tool box. I just want some opinions on what you have used and like the most. I would like to be able to get codes of course but also be able to monitor fuel and and the like while the car is running.
Price range is under $300. Just looking for a tool that I can use to not just give codes but useful in diagnosing if sensors are actually bad and what not. The cars at the house right now are:
'98 Ford Ranger
'91 Mustang 5.0
'99 Vette
'00 Honda Accord
Would be nice to get one to scan newer and older vehicles. Thanks in advance guys.
Old Nov 15, 2012 | 11:10 AM
PhilsFRC's Avatar
PhilsFRC
Default Scanner
I've got this one:
http://www.actron.com/product_detail.php?pid=16362
Works well to read and erase/clear codes. They have more expensive ones but since I don't do mechanic line work, works for me.
EDIT: Reread your stable. You'll need one of the more expensive ones. This one only does OBDII which is '96 and up. You'll need one that does BOTH OBDI and OBDII. Actron has them-around $200 +/-.
Old Nov 15, 2012 | 11:27 AM
johnson-rod's Avatar
johnson-rod
I got mine at Sears.
Old Nov 15, 2012 | 12:08 PM
StratTone's Avatar
StratTone
Which model from sears did you get?
Old Nov 15, 2012 | 12:13 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ive got the ACTRON CP9180 Make SURE that you get one that is CAN Bus enabled for the newer cars.
You realize that you DO NOT need one for the C5?? Correct?? The C5 can read its own DTCs
I purchases mine to read my C6 and JK Jeep.
If you purchase one, look on line at AMAZON.com for the best price.
BC
Old Nov 15, 2012 | 12:56 PM
PhilsFRC's Avatar
PhilsFRC
Remember if you want to read your Mustang, it's OBDI, and you'll need a dual function scanner.
Old Nov 15, 2012 | 01:08 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
I highly recommend the AutoXray EZ-Scan 6000.
http://www.autoxray.com/product_detail.php?pid=94
It's currently priced at $291 on the Amazon website.
Old Nov 15, 2012 | 05:52 PM
johnson-rod
Craftsman CanOBD2 Diagnostic Tool. I don't see an item# on it but the
UPC = 0 4217311003 2
I think it was around $125. I was employed then so money was no object.
Old Nov 15, 2012 | 10:07 PM
PhysicsDude55's Avatar
PhysicsDude55
If you have a smartphone, you might want to look into getting a bluetooth OBDII transmitter, and you can read codes, gauges, etc. from your phone.
They're only about $30 or so on Ebay, and the app is free with ads, or $5 without ads I think.
Not sure the compatibility, but worth looking into...
Old Nov 15, 2012 | 10:18 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Get a scanner that has the ability to read and monitor LIVE SENSOR DATA. That way you can look at and monitor all your sensors in operation/ Things like LTFT and O2 sensor operation.
Comes in very handy for troubleshooting.
BC
Old Nov 15, 2012 | 10:57 PM
m6 c5's Avatar
m6 c5
Ive got a scan guage II that I bought 4 or 5 years ago and it works pretty well and has a lot of extra features as well.
Old Nov 16, 2012 | 12:02 AM
shadowman1's Avatar
shadowman1
Actron CP9580A 162.75. I use an Actron at work. Great scanner with live data.
Old Nov 16, 2012 | 01:22 AM
C5Natie's Avatar
C5Natie
If you have an android phone... The Torque Pro app. Its $5 and scans all codes, deletes, reads sensors, data logs and much more. All you need is a $15 obdII bluetooth interface. Save your money, this app does more then any of those fancy scanners.
http://forums.corvetteforum.com/c5-s...hone-apps.html
Old Nov 16, 2012 | 09:35 AM
3boystoys's Avatar
3boystoys
Autoenginuity
Old Nov 30, 2012 | 02:53 PM
StratTone's Avatar
StratTone
Give me some info on the iphone apps for OBDII. Anybody using them with a cable and live data? Any good?
Old Nov 30, 2012 | 10:01 PM
z06scentair's Avatar
z06scentair
The BT Interface you can find on amazon is called ELM 327. Then as stated buy the Torque pro App and you have yourself a very nice tool for $25.00.
Old Dec 1, 2012 | 09:23 AM
emerald's Avatar
emerald
Check out Palmer Performance. I have the SCANXL Standard that I use with a laptop. They also have a wireless Iphone model. With that you can do drag and dyno along with the code reading and monitoring.
http://www.palmerperformance.com/pro...comparison.php
Old Dec 1, 2012 | 10:06 AM
sunchaser73's Avatar
sunchaser73
I have ProScan on my laptop. Check out http://www.myscantool.com/ for more info. Two of the features I like are the live sensor graphs and data-logging. Like Bill said, these features are useful for troubleshooting. It is for OBD2 only...right now it is on sale for $129.99. I've had it for 6 years now...works pretty good.
To Recomendations for a OBDII scanner.
