Hollow Camshafts.....
Old Jun 7, 2002 | 12:27 PM
DucaT's Avatar
DucaT
Default Hollow Camshafts.....
As I have read, the stock cam is rifle bored, and is hollow.
A lot fo motorcycles have gone to hollow camshafts in order to lose weight and make for a lighter valvetrain in OHC applications.
From the things I have read about the LS1, it was done to lower NVH.
So....
All you guys who are running aftermarket cams, are they hollow as well?
Or are they lopey enough so that the NVH aspect of a more aggressive cam is cancelled out?
Old Jun 7, 2002 | 12:47 PM
The One's Avatar
The One
Default Re: Hollow Camshafts..... (DucaT)
:confused:
I thought it was the valves (then only on an 02 Z06) that were hollow?
JC
Old Jun 7, 2002 | 01:21 PM
99 Corvette's Avatar
99 Corvette
Default Re: Hollow Camshafts..... (The One)
The stock cams are hollow (don't remember why) and the Z06 valves are sodium filled (not hollow) :cheers:
Jerry
Old Jun 7, 2002 | 01:52 PM
C5Noir's Avatar
C5Noir
Default Re: Hollow Camshafts..... (99 Corvette)
Jerry
Yup and don't cut those valves open, Na and K with lots of O2 = BANG!
Old Jun 7, 2002 | 01:55 PM
The One's Avatar
The One
Jerry
Sort of... ;) This is from an article on the Z06 cam:
"With the higher lift, we needed to reduce the mass of the valvetrain or start getting into a float condition," John Juriga commented. "We went to hollow stem intake and exhaust valves, very similar to what we used in the ’96 LT4. We pushed the edge with a state-of-the-art, 0.8-mm. (valve stem) wall thickness–very thin stuff. The exhaust stems are sodium-potassium filled."
They would have to be hollow to fill them with something, eh? :D
Old Jun 7, 2002 | 02:48 PM
vanroth's Avatar
vanroth
Default Re: Hollow Camshafts..... (C5Noir)
Not O2 but H20!!!
vanroth
Old Jun 7, 2002 | 04:12 PM
Walt Donovan's Avatar
Walt Donovan
My guess for the hollow cam is that it's hollow because it can be. GM finally started making cams with bigger journals (the LS1 is 55mm). This allows a lot of advantages. Base cirle is bigger. That means lower presure angles and quicker accelerations without negative radius flanks. The cam is stiffer so natural frequencies are raised a bunch. Whole valvetrain is more controllable. Which brings me to the hollow core. There's so much camshaft now, they don't need the middle any more.
Old Jun 7, 2002 | 09:54 PM
AP's Avatar
AP
Jerry
Wow ! Wouldnt that make them pretty fragile...
Old Jun 8, 2002 | 12:57 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
Default Re: Hollow Camshafts..... (Walt Donovan)
great reply Walt, thanks :cheers:
Old Jun 8, 2002 | 12:18 PM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
I've installed numerous aftermarket cams in LS1's and LS6's... from Lunati, Comp Cams, and Crane.. all were rifle bored..
Old Jun 8, 2002 | 02:28 PM
AP's Avatar
AP
Default Re: Hollow Camshafts..... (nevrenuf)
C:cool::cool:L
Old Jun 8, 2002 | 03:11 PM
DucaT's Avatar
DucaT
Default Re: Hollow Camshafts..... (NewVetteLover)
Great, Thanks neverenuf
That was exactly the answer I was looking for.
I am not really sure if I understand why they are hollow beyond the weight advantage. Yeah, OK, the cam is larger and so now it is strong enough so that it can be hollow.
Like I originally posted, I can't figure what the hollow part has to do with the Noise/Vibration/Harshness aspect.
Whatever the advantage is, I'm glad that the aftermarket cams have included that in their construction.
Thanks fellas...........
Old Jun 8, 2002 | 06:00 PM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
I'm told that the hollow bore is a stress relieving process and that it allows the heat treatment to be more effective..
To Hollow Camshafts.....
