Right front wheel bearing going bad
Old Nov 18, 2012 | 09:52 PM
DansBlkonBlkZ06's Avatar
DansBlkonBlkZ06
Default Right front wheel bearing going bad
I was having a vibration during hard braking at a track day. The right front wheel bearing is shot. I bought the TimKen replacement at AutoZone. The AutoZone guy said I should replace both fronts. The left front (original stock) still feels good. Should I spend the extra money and swap out the left front too?
Old Nov 19, 2012 | 01:35 AM
mighty mousd's Avatar
mighty mousd
I didn't and that was over 75k ago. I spend where I have to.
Old Nov 20, 2012 | 03:06 PM
2kbluestreak's Avatar
2kbluestreak
I'm a bearing engineer and get paid enough to consider myself an expert. Identical bearings in a system do not fail at the same time given equal loads and speeds. They have a life dispersion. You should not have to replace the other side. On the other hand, the bearings are capable of a longer life than the grease that lubricates them. Time at high temperatures is what reduces the life of grease. If your C5 was tracked a lot on a road course, both front bearings and grease will have seen some high temps. Unfortunately, you cannot clean out and re-pack these bearings. If the other side starts making noise, replace it.
Old Nov 21, 2012 | 01:29 PM
Deanos/2004/C5's Avatar
Deanos/2004/C5
Was your bearings making any unusual noises as well? For example a squeaking or rattling noise that sounded like brake drag. I have a 2004 vette, and I just replaced the pads and rotors all around. I still have a rattling coming from the front end, the brakes are great, no vibrations or squeaking, I just cannot figure out the rattling from the front end. I have taken off the center caps, retorqued the lugs and still no change. Do any of you guys have a suggestion as to what it may be?
Old Nov 21, 2012 | 02:07 PM
BigGun's Avatar
BigGun
Yea...wheel bearing. Pull the pads and spin the wheel by hand. Should be smooth as butter. Any drag or sound and your bearing is bad.
Old Nov 21, 2012 | 03:46 PM
Deanos/2004/C5
I had a feeling that might be the issue, I am taking tha car to the dealer on Friday, I don't have the capabilities to do this kind of work at the house.
Thanks Brother!!
To Right front wheel bearing going bad
