GM ceramic pads
Old Jun 7, 2002 | 06:07 PM
mmorse's Avatar
mmorse
Default GM ceramic pads
Anyone use these? Looking to see if they are a good substitute for OEM pads for normal street use. Looking for a cheaper alternative to OEM pads that perform as well with no noise. I don't race or autocross.
Old Jun 7, 2002 | 09:55 PM
SNW Vette's Avatar
SNW Vette
Default Re: GM ceramic pads (mmorse)
Hi,
I have ~500 miles on a set of front & rear Durastop Ceramic Wave II pads. The reduction in dust is absolutely dramatic compared to my C5 stockers. I do have a squeal in the right rear that started just a couple of miles back. I haven't got a chance to take a look back there yet to see what’s going on. I could not perceive a change in the brake feel after the change.
Good luck,
Steve
:seeya
[Modified by SNW Vette, 8:58 PM 6/7/2002]
Old Jun 7, 2002 | 10:22 PM
BAD 99's Avatar
BAD 99
Default Re: GM ceramic pads (SNW Vette)
I have GM ceramic i got from the dealer :smash:
I love them , the stopin power is a little better on very hard braking[maybe]
BUT the best part is NO DUST i have chrome z06 rims , and when it time for a wash job , almost NO dust :cheers:
but they do smell :crazy: on hard braking
Old Jun 7, 2002 | 10:24 PM
BAD 99's Avatar
BAD 99
forgot..........................NO NOISE AT ALL FROM MINE :smash: :yesnod:
Old Jun 8, 2002 | 11:05 AM
01Pewter's Avatar
01Pewter
CI 2-3-4-5-6-7-8-9-10 Vet
CI-X Auto-X Champ (street tires)
Cruise-In IX AutoX Winner
I put the GM ceramic on about 2000 miles ago (1 month) :D
They made a little noise before I bedded the pads.
After bedding they have been quiet. :cool:
I installed new GM drill & slotted rotors at the same time.
Old Jun 9, 2002 | 03:18 AM
BAD 99's Avatar
BAD 99
Default Re: GM ceramic pads (01Pewter)
are your hubs rusty now??[hubs of the disc] mine are , ive got to fix it someday
Old Jun 9, 2002 | 10:22 AM
01Pewter's Avatar
01Pewter
Default Re: GM ceramic pads (BAD 99)
are your hubs rusty now??[hubs of the disc] mine are , ive got to fix it someday.
Before installing the rotors I had them zinc plated.
The unwiped areas have not rusted.
I wire brushed the hubs before installing the rotors, but they will continue to rust. :rolleyes:
Old Jun 9, 2002 | 06:01 PM
C5Noir's Avatar
C5Noir
How much are the GM ceramics and where did you get them?
Old Jun 9, 2002 | 10:53 PM
01Pewter's Avatar
01Pewter
Default Re: GM ceramic pads (C5Noir)
I got the pads from Fichtner Chev.
Fronts $98.85
Rears $70.78
Old Jun 10, 2002 | 08:18 AM
Busted Knuckle's Avatar
Busted Knuckle
Got them on the 99' and 00' with aftermarket rotors and ZO6 calipers and NO PROBLEMS and the dust is minimal. Best thing we ever did for adding life and keeping the looks of our Fikse FM5's on the 99'. :D :cheers: :flag
Old Jun 10, 2002 | 03:43 PM
MJM's Avatar
MJM
I just put a set of Raybestos ceramic pads on my Z06. I use them during the week between track events where I use PFC 01 & 99 compounds front and rear.
They obviously don't stop as well as the race pads but they don't dust or squeal.
For street use, I am very happy with them.
They are available at Kragen stores and have a lifetime warranty.
Matt
[Modified by MJM, 2:45 PM 6/10/2002]
Old Jun 10, 2002 | 08:42 PM
FarmerBob2001's Avatar
FarmerBob2001
Fronts $98.85
Rears $70.78
How much are the OEM pads, and what is the expected lifetime of both?
Old Jun 10, 2002 | 10:20 PM
01Pewter's Avatar
01Pewter
Default Re: GM ceramic pads (FarmerBob2001)
You can check Fichtner's thread for pricing.
http://forums.corvetteforum.com/zerothread?id=312229
I do not know what the expected lifetime is for either pad.
Old Jun 16, 2002 | 12:34 AM
NOSLOW's Avatar
NOSLOW
I was just searching this forum for some info about these Durastop ceramic pads, and came across this post. The low dusting sounds good to me, but I might go for better performance.
The prices listed in this post aren't the best. Has anyone checked out GMpartsdirect.com? There prices seem to consistently squash GM WHOLESALE prices!! (isn't that what Fichtner's charges?). Here's a list of GM part #'s from an email I've received from gmpartsdirect.com - just go to their website and enter in the part numbers for an instant price. Apparently, they get a lot of requests for Z06 parts because I didn't request those parts. The pads were $70.61, front and $50.56 for the rears.
Thanks for your interest in http://www.gmpartsdirect.com and our C5 Corvette parts. Here is a list of GM part numbers to convert your C5 coupe to have the look and performance like the NEW Z06.
APPEARANCE
12496964 car cover custom fit deluxe, gray in color with sealed seams and corvette logo
12371222 car cover custom fit, gray in color with corvette logo
12371222 front end covers "bra", does not have cutouts for z06 package
10429629 Z06 emblem requires two total, one on each front fender
10314089 z06 405 HP emblem requires two total, one on each front fender
10424820 right front grille for brake cooling
10424821 left front grille for brake cooling
10295976 right front brake cooling air duct
10295977 left front brake cooling air duct
10440858 is the right rear brake air cooling scoop
10440860 is the left rear brake air cooling scoop
10425976 is the left rear brake cooling air duct
10425977 is the right rear brake cooling air duct
20430420 air duct screws requires approximately 16
11503647 air scoop nuts requires approximately 8
10444707 is the lower door opening finish panel for the right (paint to match) and must be cut for air scoop, note the original can be cut as well this number is listed for coupes only.
10444708 is the lower door opening finish panel for the left (paint to match) and must be cut for air scoop, note the original can be cut as well this number is listed for coupes only.
9593804 front wheel 17x9.5 with option code QE1
9593806 rear wheel 18x10.5 with option code QE1
9594325 wheel centers requires 4
12455500 left drivers upper seat back cover BLACK
12455501 right passenger upper seat back cover BLACK
12564257 LS6 left fuel injection rail cover RED
12564258 LS6 right fuel injection rail cover RED
BRAKES STANDARD AND PERFORMANCE 97-02
88895128 left front caliper red
88895129 right front caliper red
88895130 left rear caliper red
88895131 right rear caliper red
88926732 Durastop-Front left, # GM Drilled and slotted rotors, for all C5's including ZO6
88926731 Durastop-Front right, #GM Drilled and slotted rotors, for all C5's including ZO6
88926734 Durastop-Rear left, #GM Drilled and slotted rotors, for all C5's including ZO6
88926733 Durastop-Rear right, #GM Drilled and slotted rotors, for all C5's including ZO6
88909667 Durastop-Front, #GM Ceramic Pads
88909668 Durastop-Rear, #GM Ceramic Pads
10445847 standard front rotor left
10445846 standard front rotor right
10445859 standard rear rotor left
10445858 standard rear rotor right
12530681 y07-67 standard oem pads front
88952008 y37 standard oem pads front
12530688 standard oem pads rear
12480155 GM performance front rotor left
12480156 GM performance front rotor right
PERFORMANCE UPGRADES 97-02
25329389 uph44 for the Z06 ULTRAGUARD OIL FILTER
25314814 front intake air duct for LS6 2001 with single opening
12567571 front intake air duct for LS6 2002 with dual openings
25179711 Mass Air Flow meter LS1 97-00
25318411 Mass Air Flow meter LS6 01-02 Z06
12570281 flywheel is for LS1 6 speed option MM6 01-02.
12570806 flywheel is for LS6 6 speed option M12 01-02 Z06
88890524 LS6 intake with intake gaskets
12533587 intake gaskets
12560950 LS6 factory cam
12480033 LS6 hot cam includes 16 LS6 valve springs
Gaskets needed to do cam swap are as follows
12558013 front cover gasket
12559271 water pump gasket 2 required
12560696 valve cover gasket 2 required
12558178 intake valley gasket
EXPORT LENS and LAMPS
Export parts are designated for GM automobiles overseas. Export parts, may or may not fit U.S. GM cars. If you order an export part and it does not fit or you do not want it, be committed to keeping the export part. GM does not allow any returns on EXPORT parts. Please do your research to insure this is the part you want and that it will work on your GM automobile.
10302677 left export headlight
10302676 right export headlight
10274295 left export fog lamp front
10274296 right export fog lamp front
5977961 left export front signal lamp
5977962 right export front signal lamp
12533323 left export rear fog lamp
12533324 right export rear fog lamp
10270419 left export back-up and stop lamp
10270420 right export back up and stop lamp
10253891 left export rear signal and stop lamp
10253892 right export rear signal and stop lamp
You can go to http://www.gmpartsdirect.com on our home page there are spaces provided to enter in your part numbers to check prices or place your order.
If you have a question regarding this email please include all contents of this email, including the original email you sent, so we can keep track of the conversation. Please keep in mind gmpartsdirect.com cannot be held responsible for incorrect part numbers. Please feel free to validate the accuracy with your local dealer. As a note, special order and electrical parts are non-returnable so please verify your part numbers are correct.
Email response hours are from 9 to 6 est, Mon to Fri. Orders and emails after 3pm Friday est. will not be processed until Monday.
thanks http://www.gmpartsdirect.com
To GM ceramic pads
