C5 Damper alignment?
Old Nov 20, 2012 | 12:31 PM
Rconce01's Avatar
Rconce01
Default C5 Damper alignment?
a couple questions
what is the proper way to keep the engine from spinning when removing the damper bolt?
I used a old steel differential carrier clamp wedged on one of the fins and resting on the cross member to loosen the bolt.
when I took off the damper I did not mark the position relative to the crank since it doesn't have a alingment key I figured its position wasn't important.
Do you need to mark the position of the damper to the crank. I've read in some forum threads that you do and others that you don't.
obviously I didn't do it and I'm just wondering if there might be vibration issues.
torque is 240 ft lbs for the bolt right?
Old Nov 20, 2012 | 01:44 PM
kp1's Avatar
kp1
If your damper has a balancing pin or pins inserted into the front face that means the damper was used to dial in the balance of the engine and reinstallation w/o having it oriented in the same position may cause an issue. Not certain what the 'correct' way is to keep the engine from turning. I put them in 4th gear and put the emergency brake on and I chock the tires. I've removed and reinstalled quite a few with that method w/o issue.
Old Nov 20, 2012 | 01:53 PM
Rconce01's Avatar
Rconce01
Ok cool not sure if this one has balancing pins it does have about a dozen holes along the perimeter in an un even pattern.
its an auto so the gear thing an ebrake dont apply
thanks
Old Nov 20, 2012 | 03:44 PM
69SSC5's Avatar
69SSC5
Kent Moore Tool (flywheel holder). I forget the J #, just google it and the number will pop up
Old Nov 20, 2012 | 07:10 PM
Paul 75 L82's Avatar
Paul 75 L82
Use the Hawk Balancer installation tool to install the balancer. He's on the forum and it works great. Use a Ridgid strap wrench to hold the balancer when you put the 240 lbs of torque on your new ARP bolt.
Old Nov 20, 2012 | 08:27 PM
Rx7Rob's Avatar
Rx7Rob
Take a look in all those holes. I believe there are three different sizes of the balance pins. They're differentiated by the clearance from the end of the pin to the front of the balancer.
Old Nov 21, 2012 | 05:17 AM
vettenuts's Avatar
vettenuts
Not the GM OEM bolt, it is TTY and there is a very specific procedure that must be followed. LS1howto doesn't cover this procedure and is not correct so don't follow that web site. Installation tool is key as well. Don't use a bolt to pull on the harmonic damper.
Old Nov 21, 2012 | 07:16 AM
kmetros's Avatar
kmetros
My neighbor (access to a welder) made this for me. Worked like a charm!
http://forums.corvetteforum.com/c5-t...ding-tool.html
Old Nov 22, 2012 | 11:52 AM
cptinjak's Avatar
cptinjak
Just leave the car in 4th gear with the rear tires on the ground to keep the engine from turning.
Jack
Old Nov 22, 2012 | 01:50 PM
Rconce01's Avatar
Rconce01
don't laugh but it worked great
Old Nov 22, 2012 | 01:52 PM
Rconce01's Avatar
Rconce01
enjoy cause I sure didn't
Old Nov 22, 2012 | 01:53 PM
Rconce01's Avatar
Rconce01
To C5 Damper alignment?
