Windshield Wiper Switch on 2002 Corvette
Old Nov 21, 2012 | 09:24 AM
quickblue02's Avatar
quickblue02
Default Windshield Wiper Switch on 2002 Corvette
I have a broken wiper switch that keeps the windshield washer pump running. I need to change out the wiper combo switch on a 2002 Corvette with telescoping steerring wheel column. Has anyone seen this changeout described on the forum with some photos?
thanks!
Old Nov 21, 2012 | 09:32 AM
mighty mousd's Avatar
mighty mousd
I've only seen it in the manual.
for pictures.
Old Dec 1, 2012 | 11:52 AM
quickblue02
anyone else have any ideas?
Old Dec 1, 2012 | 05:30 PM
fevest's Avatar
fevest
Well, if only the button for the washer is messed up and you have the parts. You can fix it. Mine did it. You have to have the button though. What happens is the two springs in there get weak.
You can hunt around for a small spring. I used one from a old electrical relay. Just figure out the diameter and length you need. Put it in and put the button back in..
I will work. You may need to get a couple of springs to get the size that works best.
Old Dec 1, 2012 | 10:35 PM
m6 c5's Avatar
m6 c5
well its possible to do it without taking the dash apart and just removing the trim pieces around the steering wheel and the panel under the steering column. I did it just a few weeks ago.
Old Dec 6, 2012 | 08:43 PM
quickblue02
anyone have any photos on how to do this?
Old Mar 31, 2014 | 08:35 AM
SpeedUp's Avatar
SpeedUp
Sorry to revive an old thread, but this is what SEARCH gave me.
I am having the same issue as the OP, I have an 2002, and the washer motor runs on its own.
I found some instructions for replacing the headlight and directional switch here
These should apply for taking out the washer control switch right?
Any help or tips would be greatly appreciated!
thanks!
Old Mar 31, 2014 | 03:48 PM
m6 c5's Avatar
m6 c5
No that's on the left side what you are talking about is on the right side. After you get the trim off it is pretty easy from what I remember so that part if it would help.
To Windshield Wiper Switch on 2002 Corvette
