TPS question
Old Nov 23, 2012 | 03:52 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Default TPS question
Hi guys, normally I haunt the C4 section since that is what I have but I have a question that would be better answered here. I am putting an Edelbrock Pro Flo XT intake on my car and it uses an LS style throttle body. Is there any way I can do something so I can adjust the tps, my voltage is showing over 1 volt at idle position. Any insight would be much appreciated.
Old Nov 23, 2012 | 05:18 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You are correct. The C5 TB does NOT have an adjustable TPS. If your careful, you could probably SLOT the TPS mounting holes so that you could rotate it. Your really not going to get much adjustment doing that but, it something.
Another thing to think about. The C5 Throttle By Wire TB does NOT have any throttle stops
How are you controlling the Throttle By Wire OR are you using a F body cable actuated TB??
If I remember correctly, the C4 needs 0.45 VDC for proper idle.
Old Nov 23, 2012 | 07:34 PM
Midnight 85
Close, it's 0.54 and I am using a throttle cable. I'll have to see if I can do a little more adjusting of the throttle blades to get it down to an acceptable number, thanks.
To TPS question
