Gaskets for headers
Old Nov 24, 2012 | 11:31 AM
billvh's Avatar
billvh
Default Gaskets for headers
When installing headers, what is the best gasket to use? I have heard use stock GM, are Felpro replacements as good? What about their high performance gaskets, or Mr Gasket type soft aluminum or copper?
Old Nov 24, 2012 | 11:38 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I've had the best reults using the STOCK GM metal layered gaskts on headers
Old Nov 24, 2012 | 11:44 AM
bumble-z's Avatar
bumble-z
I agree.
Old Nov 24, 2012 | 01:28 PM
LiteraCola's Avatar
LiteraCola
Most, if not all, manufacturers include gaskets when you purchase headers. LG Motorsports, for example, sent me OEM LS gaskets when I bought my LT's. I have heard that there is no better gasket than the OEM unit. Good luck!
Old Nov 24, 2012 | 03:52 PM
corv1998's Avatar
corv1998
When i installed my american racing headers i purchased the oem gaskets at local dealer . They did and still do not leak at all , would get them again . Toss the ones that come with headers
Old Nov 24, 2012 | 04:01 PM
tiojames's Avatar
tiojames
My muff guy swears by the factory ones. He told me not to bother with buying new ones when he put the headers and the rest of the 3" system on the vert as he would use the old gaskets. That was 5 years ago and no leaks yet, and with the huffer it has a lot of exhaust pressure to hold.
Old Nov 24, 2012 | 04:51 PM
billvh's Avatar
billvh
I have a used set. Looks like the way to go is factory. Don't think I'll try and reuse the stock ones though. Thanks for the info
Old Nov 25, 2012 | 12:55 PM
Sales@Texas-Speed's Avatar
Sales@Texas-Speed
Premium Supporting Vendor
We prefer the GM gaskets for sure!
Old Nov 25, 2012 | 02:14 PM
Arnie Chamberlain's Avatar
Arnie Chamberlain
I reused the stock ones, just cleaned them up with some brake cleaner, brass brushed off the carbon deposits, and trimmed them a little to fit the header flanges.
Then I notched the two outmost bolt holes with a tinsnips so I could get the header in place on the outer two bolts, then slide the gasket in, then install and tighten the balance of the header bolts. That was the key to doing it easy for me.
Old Nov 25, 2012 | 04:43 PM
tstrobl1's Avatar
tstrobl1
Great tip! Using GM multi-layer and notching the end bolt holes. I'll definitely be doing this. Thanks.
Old Nov 25, 2012 | 06:13 PM
PhilsFRC's Avatar
PhilsFRC
Default GM Exhaust Gaskets
Old p/n 12558573
New p/n 12617944
Old Nov 25, 2012 | 07:22 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Old Nov 26, 2012 | 10:55 AM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Agreed
Old Nov 26, 2012 | 11:10 PM
hydrasport's Avatar
hydrasport
I was told to reuse my original factory gaskets. I just added a little orange high temp silicone sealant to both sides. Not leaks. Never put sealant on both sides of a gasket, except on the stainless factory GM exhaust gaskets. It only takes a little.
To Gaskets for headers
