Tire replacement
Old Nov 24, 2012 | 08:20 PM
flexvette's Avatar
flexvette
Default Tire replacement
Do I need to replace the seals on the valve stems(TPMS). Removing GY EMT's replacing with Nitto 555 same sizing.
I do not have any leaks just worn tires at 40K klms with no aggressive driving.
2003 Coupe 6M
Old Nov 24, 2012 | 08:36 PM
jerrys vette's Avatar
jerrys vette
no---i just replaced my 4 tires and did not do anything with valve stems.
Old Nov 24, 2012 | 08:57 PM
87SAM's Avatar
87SAM
I would. They are most likely old and will never be easier to do than now.
Old Nov 24, 2012 | 09:01 PM
Baldfart's Avatar
Baldfart
If you don't, you will regret it. No time like the present!
Old Nov 24, 2012 | 09:54 PM
DaDuck's Avatar
DaDuck
2003 Coupe 6M
You will be happy with the Nitto's. Unless you like to hear the GY tires whinning down the road.
Old Nov 24, 2012 | 10:54 PM
dblerman's Avatar
dblerman
You can pick up those o-rings for like $2 at just about any plumbing/hardware store. I see no reason not to change them.
Old Nov 24, 2012 | 11:15 PM
flexvette's Avatar
flexvette
DiscountTire has the kit $3 per tire , I guess it is cheap insurance. I thought more owners would report air leaks from these , being 10 yrs old .
Thanks for the input.
Old Nov 25, 2012 | 12:46 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
It may be cheap insurance to replace the seals, but your sensors are near the end of their battery life if they are the originals. They will be failing soon.
You might want to consider replacing the sensors or rebuilding yours with new batteries.
Old Nov 25, 2012 | 10:42 AM
rprinty's Avatar
rprinty
TPMS rebuild kits (o-ring, valve core, valve cap, and nut) are $1.66 at Rock Auto. And yes, replace them. I just went through that and had to do the job twice because I didn't replace them the first time.
Bob
Old Nov 25, 2012 | 10:52 AM
Baldfart's Avatar
Baldfart
This is true.
To Tire replacement
