cam swap ?
Old Nov 25, 2012 | 12:05 PM
SPEED750's Avatar
SPEED750
Default cam swap ?
Do you have to pull the radiator to do a cam swap in a C5 ? How hard of a job is it ? I've been told that a cam swap in a LS1 is easier than doing one in a regular old small block. Any input ?????
Old Nov 25, 2012 | 01:15 PM
dblerman's Avatar
dblerman
Yes the radiator must come out (and ac condenser moved slightly) to allow enough room to slide the cam out.
It's not a difficult job, just a lot of little things that need to be done correctly.
There is a guide on LS1howto, but there are a few things he does wrong and/or omits so I highly recommend getting a service manual and just using the LS1howto as a visual guide.
Old Nov 25, 2012 | 01:28 PM
NukeC5's Avatar
NukeC5
Due to the cradle having to be lowered and the steering rack removed, along with the other things mentioned, I'd say a cam swap is more difficult in the C5 than older gen I vehicles. I have done a few that only require the radiator to be removed. This car is much more involved.
Old Nov 25, 2012 | 01:31 PM
Paul 75 L82's Avatar
Paul 75 L82
Old Nov 25, 2012 | 01:58 PM
RonSSNova's Avatar
RonSSNova
Cradle lowered? I didn't do that.
However, cam swap is a big job. Lifter replacement is smart at the same time which means heads off, might as well upgrade those as well.
Budget? What budget!
Old Nov 25, 2012 | 09:42 PM
Rx7Rob's Avatar
Rx7Rob
I just pulled my radiator the other day in prep for a cam swap. Its a pain in the neck to get out but not too bad. Here's a link to the guide:
http://www.ls1howto.com/index.php?ar...72ec67f76905f9
Remove the radiator hose from the radiator on the passengers side. The damn spring clamp was in a bad position for me to remove. I'm replacing every one with screw type hose clamp. Also keep an eye on the "hook" on the radiator bottom /side of the passengers side, it will want to grab the wire harness.
Old Nov 25, 2012 | 09:48 PM
onspeed's Avatar
onspeed
How long would you estimate for someone with a decent mechanic ability. 1 weekend? I've done clutches, pulled an engine, head gaskets, etc. Only done basic stuff with the C5 though. A weekend?
Old Nov 25, 2012 | 09:58 PM
dblerman's Avatar
dblerman
As long as you have all the required tools lined up and don't hit any snags you should be able to do it in a weekend. The biggest PITA is getting the steering rack out of the way.
What cam/springs/heads/etc setup are you going with?
To cam swap ?
