Help 98c5 auto has reverse only ????
Old Nov 27, 2012 | 11:57 AM
franklc's Avatar
franklc
Default Help 98c5 auto has reverse only ????
Good anyone tell me if there is anything i can do to check this out . Its 98 c5 auto 100k . Backed in to a parking spot and when i came out it wouldnt go in any gear but reverse and park/i think park worked. But no forward gears. , anyone with info please.
Old Nov 27, 2012 | 12:06 PM
NukeC5's Avatar
NukeC5
You may need to check the transmission linkage. It will be in the rear on the drivers side of the transmission.
Old Nov 27, 2012 | 12:11 PM
CactusCat's Avatar
CactusCat
Could be a lot of things but more than likely, the shifter cable has probably let go. And unfortunately, it's probably going to require a tow to either your mechanic or your garage, where you'll have to get under the car to determine the exact cause. Either way, it's a PITA..... good luck and let us know how it turns out. There have been some cheap and innovative fixes for this similar problem. It's probably not the transmission (hopefully).
Old Nov 27, 2012 | 12:18 PM
calinator's Avatar
calinator
I had the same issues as you last year. Reverse and Park were fine but no forward gears, required a transmission rebuild. Hopefully not the same for you.
Old Nov 27, 2012 | 01:08 PM
franklc's Avatar
franklc
Thanks i had it towed on lift now cable is good . Off the ground you can put it in drive and it will turn back tires,barely like its really slipping. So i guess the rebuild is whats gonna have to be done. Thanks alot
Old Nov 27, 2012 | 07:12 PM
CactusCat's Avatar
CactusCat
Kinda wierd. No problems whatsoever and all of a sudden, BOOM and the transmission won't go in the forward gears? Did you have any indication this might happen? Fluid levels checked out ok? Has the car been driven hard? Hopefully, it's nothing really bad. A rebuild isn't the worst thing in the world, but just seems unusual to just simply appear out of thin air. Keep us updated....
Old Dec 6, 2012 | 04:29 AM
franklc's Avatar
franklc
had to have trans rebuilt said it looked like it was way over heated , will be adding a cooler. thanks guys
Old Dec 9, 2012 | 04:31 PM
burnside99's Avatar
burnside99
Having same problem with my 99 coupe waiting for shop to call with a opening.
To Help 98c5 auto has reverse only ????
