tire size suggestions before i pull the trigger
Old Nov 28, 2012 | 08:56 AM
andy9743's Avatar
andy9743
Default tire size suggestions before i pull the trigger
car currently has
245 45 zr 17 fronts
275 40 zr 18 rears
looks like these are stock sizes and i should stick with them or go a different size? car is just street driven. suggestions?
Old Nov 28, 2012 | 09:11 AM
Jackb0524's Avatar
Jackb0524
I was told 18/18 or 19/19 looks meaner instead of a 17/18 or 18/19 ratio. Then lower it
Old Nov 28, 2012 | 09:13 AM
maxx2200's Avatar
maxx2200
If you don't go with stock sizes, be sure and keep the necessary stagger.
Old Nov 28, 2012 | 09:14 AM
andy9743's Avatar
andy9743
the car already has nice looking aftermarket rims on it i'm not planning to change them out. just not sure if i should stick to stock sizes or if i can or should do anything different?
Old Nov 28, 2012 | 09:26 AM
maxx2200's Avatar
maxx2200
Proper stagger is important (about 1" bigger in the rear) to keep in mind. Try this site. You can play with tires different sizes to see what fits. I used this site when I went up to 18/19 and it was very helpful.
http://www.rimsntires.com/specs.jsp?...ize%20comparer
Old Nov 28, 2012 | 12:38 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I don't know if you have the stock '99 FRC size wheels (17" x 8.5" front and 18" x 9.5" rear).
If you do, then you may be limited to how big a tire you can fit on.
I put 255/45/17 (26.1" dia) front and 285/40/18 (27.0" dia) rear tires on my FRC and they work well. These sizes are a little bigger than stock, but retain the stagger. They will also keep the speedometer fairly close (at 60.7 mph it will read 60 mph). This size will also fit on the Z06 (1" wider) size wheels.
Good luck with your choices.
Old Nov 28, 2012 | 06:15 PM
_zebra's Avatar
_zebra
those 255 & 285s will fill your wheel wells a little better than stock if you don't want to lower the car. and they're only marginally wider, so the wheel size shouldn't be an issue (assuming they're stock sizes).
Old Nov 29, 2012 | 12:17 AM
CactusCat's Avatar
CactusCat
Andy, do you know the aftermarket wheel widths? Your tire sizes are the stock C5 sizes (I have the same) and stock rims are 17x8.5 front and 18x9.5 rear. If your aftermarket rims are wider, you can put bigger tires on them. If they are stock widths, a 295 is about as wide as you can get on the 18x9.5 wheel. If they are wider than stock, then you can go wider on the tire sizes as well. As stated earlier, the key is to keep the stagger (tire diameter of the front and rear tires) the same or as close to stock as you can. Hope that helps.
Old Nov 29, 2012 | 02:29 AM
C5Natie's Avatar
C5Natie
Not necessarily true. I have a 18/18 wheel combo with my tires less then 1/2 in height difference. No issues whatsoever.
OP, I used to have 295's in the rear when I had stock sized wheels. They looked good on there.
Old Nov 29, 2012 | 10:43 AM
maxx2200's Avatar
maxx2200
"Not necessarily true"? The rear tire diameter needs to be larger than the front tire diameter.
http://forums.corvetteforum.com/c5-g...ah-issues.html
Old Nov 29, 2012 | 01:03 PM
andy9743's Avatar
andy9743
i decided to just go with stock sizes...new rubber will be on Friday...we'll see how the hankooks preform! thanks guys
Old Nov 29, 2012 | 04:27 PM
C5Natie's Avatar
C5Natie
Not by 1in. as you stated. My fronts are 25in tall while my rears are 25.5in. As I said, no issues.
Btw it should be obvious no one would ever mount a taller tire in the front. Lol
Old Nov 29, 2012 | 06:10 PM
maxx2200's Avatar
maxx2200
Old Nov 29, 2012 | 09:28 PM
Arnie Chamberlain's Avatar
Arnie Chamberlain
275/40R17s front and 305/35R18 rear with Cray Scorpions (stock Z06 size rims)
Slammed, 0 rub.
Old Nov 29, 2012 | 11:47 PM
slow ride's Avatar
slow ride
On a stock size non-z06 wheel package you could run something like a 255/40/17 in front and a 285/35/18 out back. Little lower profile for looks and a touch wider. A few different companys make tires in this size.
To tire size suggestions before i pull the trigger
